Old 11-20-09, 0:03   #1 (permalink)
  Total: 23 Power: 2
Exclamation Squeaky Clutch
now before you guys say "search the threads" I have already done that multiple times, spray WD-40 and using grease on just about anything connected to the clutch pedal and still squeaks.
Now a friend who used to work on the car before I bought it said it might be the pressure plate?? Saying that the dust from the clutch disc is causing it. If this is true would I just have to change my pressure plate and clutch disc and might as well put in a 9lb flywheel while I'm down there, and the squeaks will go away? car now has 180,400 on it, any suggestions will help thank you.
GuiltySoul is offline   Reply With Quote
Old 11-20-09, 13:57   #2 (permalink)
Shove it!
  Total: 1903 Power: 5
Zach's Avatar
what exactly squeaks and when does it squeak...you left the most important details out
I see you trollin I be ragin
Parting out Gray 89 GT
Originally Posted by Kansas
Old 11-20-09, 15:16   #3 (permalink)
  Total: 23 Power: 2
sorry, um its when ever I press on the clutch pedal even when pressing slightly it squeaks, hope that helps...
Old 11-20-09, 15:32   #4 (permalink)
  Total: 10 Power: 2
have the same problem and I have no clue what the problem is
93 mx6 ls: KLDE, Dropzone springs, headers, ebay cat delete, Monza catback, outlaw spacers, awr motor mounts.
davids8126 is offline   Reply With Quote
Old 11-20-09, 22:59   #5 (permalink)
  Total: 20 Power: 2
Is the pin on your slave cylinder rusty at all?
bladirka is offline   Reply With Quote
Old 11-20-09, 23:12   #6 (permalink)
  Total: 23 Power: 2
pin? wheres that located? If its under the dash, last I checked I didn't see anything rusty but like I said b4 I greased everything connected to the clutch pedal. But if I'm looking at the wrong place, kindly show me where...
Old 11-21-09, 16:03   #7 (permalink)
  Total: 10 Power: 0
squeaky clutch pedal, most likely caused by the pedal return spring... check it out... I have the same issue and have found that the spring is what is causing the noise. no idea how to fix it as of yet (maybe new one), lubrication was a temporary solution.
bomb_one is offline   Reply With Quote
Old 11-21-09, 20:44   #8 (permalink)
  Total: 10 Power: 0
i also have this problem, i bought the car about a month ago, and a week later it was squeaking i havent figured out the problem but it could be the return spring, if the dealership lubed it up and a week later it was squeaking again but i have noidea
ieetbred is offline   Reply With Quote
Old 11-22-09, 14:55   #9 (permalink)
Dead Babies
  Total: 113 Power: 3
anthrax1202's Avatar
Just turn the music up.
Originally Posted by JoeyV View Post
im a gay drinker, i have sexy/fancy drinks with my girlfriend thats it
anthrax1202 is offline   Reply With Quote
Old 11-22-09, 21:50   #10 (permalink)
  Total: 23 Power: 2
lol I have, but I trying to make my 6 perfect without any flaws. I'm a neat freak when it comes to cars, too bad I can't stay the same way with my room. But I'll check again under the dash to see if I missed anything.
Old 11-24-09, 14:51   #11 (permalink)
  Total: 408 Power: 5
PaulG's Avatar
White lithium grease is the only one that will eliminate the squeak for any length of time, the other lubes are just a temp fix.
http://www.mx6.com/forums/2g-faq-mai...ky-clutch.html (How To Fix: Squeaky Clutch)
1997 MX-6 LS
Old 11-27-09, 17:13   #12 (permalink)
  Total: 26 Power: 3
I had this problem too. I still get it every once in a while. My squeaking was coming from two places: the clutch pedal spring inside the car, AND, (this one took me a while to figure out) the release arm on the transmission.
If you know where the clutch slave cylinder is, the arm that the slave cylinder pushes on when you clutch is the release arm. There is a little rubber boot over top of where the arm goes into the tranny. I took WD40 with the little red straw on, stuck it into the boot and into the tranny and sprayed. No more squeaks.
MX6Waterloo is offline   Reply With Quote
Old 11-27-09, 22:19   #13 (permalink)
  Total: 23 Power: 2
thanxs for the info, I will investigate
