all truoble codes for OBD1 !!!!!!!!!!!!!! check it out - Mazda MX-6 Forum
post #1 of 4 (permalink) Old 8-23-10, 16:11 Thread Starter
I was reading that MC Spada wanted to make up a post for all the codes so everybody can see what codes are what.
Since I'm bored, figured I'd take it upon myself to do it.
These are taken directly from the Haynes Manual and a couple from "mike's PGT site" at 1993-1995 Engine Controller Malfunction Codes
The OBD-1 computer system was used in the 93-95 Probes.
To check for OBD-1 codes, use a paperclip and insert it into the 10 and ground pins in the diagnostics box under the hood by the battery. please make sure the car is turned off :roll: Once the paperclip is inserted, turn the key to the "on" position, but do NOT start it. Start to read the codes, quick flashes are single digits, and slightly longer flashes represent 10's or 100's. ie: 2 long flashes and 3 short flashes would be code 23.
OBD-1
02- crankshaft position (ckp) sensor or circuit
03- camshaft position (cmp) sensor or circuit
04- camshaft/crankshaft position sensor or circuit
05- knock sensor
08- Mass Airflow (maf) sensor or circuit
09- coolant temperature sensor or circuit
10- Intake air temperature sensor (IAT)
11- Intake air temperature (IAT) sensor or circuit
12- Throttle Position sensor (TPS) or circuit
14- Barometric Pressure Sensor
15- Oxygen sensor or circuit
16- EGR valve position sensor or circuit
17- Oxygen sensor (check the fuel and ignition system performance)
23- Rear 02 sensor inactivation error
24- Rear 02 sensor inversion error
25- Fuel Pressure Regulator Control Solenoid or circuit
26- Solenoid valve(purge control) or circuit
28- EGR vaccum solenoid
29- EGR solenoid vent or circuit
34- Idle Air Control(IAC) valve or circuit
41- VRIS #1 solenoid
46- VRIS #2 solenoid
67- Cooling fan relay or circuit
69- ECTF sensor
111- System pass
112,113- Intake Air Temperature(IAT) sensor or circuit
116,117,118- Engine Coolant Temperature(ECT) sensor or circuit
121,122,123- Throttle Position Sensor(TPS) or circuit
157,158,159- Mass Air Flow(MAF) sensor or circuit
172,173,179,181- Heated oxygen sensor(H02S) or circuit
211,212,213- Ignition system
214,244- Camshaft position(CMP) sensor or circuit
327,332,337- EGR function sensor or circuit
411,412- Idle Air Control(IAC) valve or circuit
452- Vehicle Speed Sensor(VSS) or circuit
511,512,513- PCM
519,521- Power Steering Pressure(PSP) switch or circuit
522- Transmission range sensor or circuit
536- Brake On/Off (BOO) switch or circuit
538- Dynamic response test
539- a/c sensor or circuit
554- Pressure regulator solenoid valve or circuit
559- a/c relay or circuit
563- cooling fan relay(high speed) or circuit
564- cooling fan relay(low speed) or circuit
565- Purge control solenoid valve or circuit
571- EGR solenoid valve(vent) or circuit
572- EGR solenoid valve(vaccum) or circuit
998- PCM
goodsonjarrett is offline
post #2 of 4 (permalink) Old 8-23-10, 16:17
Administrator's Avatar
Quoted: 1 Post(s)
Power: 6
Garage
Thanks a lot for posting this up here! I am sure this will help many members for some time to come.
Nadeem
Originally Posted by Administrator View Post
All I really want to see is her car anyways. I like cars more than girls.
Nadeem
Administrator is offline
post #3 of 4 (permalink) Old 8-23-10, 16:20
Awesome reference Im sure to use it!.
There thing we know; then there are things we know we don't know...then there thing we don't know we know and finally there are thing we dont know we dont know
REASON is offline
post #4 of 4 (permalink) Old 8-23-10, 16:36 Thread Starter
i got more hold on here comes obd2.....
