Friendsofdonr... Build thread - Page 6 - Mazda MX-6 Forum
 11Likes
post #76 of 900 (permalink) Old 11-7-12, 10:50 Thread Starter
friendsofdonr's Avatar
Quoted: 35 Post(s)
Garage
Thanks. I'm gonna try and have this ready to roll for spring. Luckily for me I now have a garage and since school will be out in a few weeks I plan on having the grinding done by january and then tanked and a valve job by the end of january. I think i need to run different retainers (Rather than stock) if i run the eibach dual valve springs so I probably wont do that at this moment in time. I'm also gonna get a p5 intake manifold and run my vris solenoids on it to activate the butterflies then port and polish that. Between the head and the intake manifold this thing should breath really well. My only hope is that when I mash it from a start it doesnt drop on its face from a lack of low end torque. I know high end with this set up should be pretty good.
http://www.mx6.com/forums/garage.php...ehicle_id=1005
http://www.mx6.com/forums/2g-mx6-gen...ld-thread.html
friendsofdonr is offline
post #77 of 900 (permalink) Old 11-7-12, 21:46
TwoPedalWarrior's Avatar
Quoted: 39 Post(s)
Considering you've had the fortitude to take your 4 banger this far, I bow to you Sir
1994 MX-6 LS ATX/MTX Swap
TwoPedalWarrior is offline
post #78 of 900 (permalink) Old 11-7-12, 21:47 Thread Starter
Quoted: 35 Post(s)
Garage
Well I haven't done a lot yet ! Lol but thank you.
post #79 of 900 (permalink) Old 11-10-12, 14:34 Thread Starter
Quoted: 35 Post(s)
Garage
So I'm gonna stop saying almost done. But this is pretty close.... three more on the intake side then onto the exhaust
Click image for larger version
post #80 of 900 (permalink) Old 11-14-12, 16:22 Thread Starter
Quoted: 35 Post(s)
Garage
I just scored an authentic fsze intake manifold off of eBay minus the fuel rail and tb for $17.50 Shipped! Now that's my kind of deal.
post #81 of 900 (permalink) Old 11-14-12, 20:31
I've always said that the biggest thing that holds the power back on the FS is the Intake manifold, cams, pistons and rods. Get rid of those 4 and you'll make some power. Get a set of 11:5 pistons with a custom set of cams and make your short runner intake manifold and you will be making better power than the KLZE.
Ze powered 626 Gutted (empty weight 2690 lbs), custom built hybrid mx3/626 shifter, chipped KLZE w/ interprep valve springs, custom mid pipe, custom I/H/E , fidanza 9lbs flywheel w/ stage 2R clutch, trans saver, PGT (eibach) suspension and driver seat, contour SVT rear sway bar, X-IAT mod 14.500 @ 95.68 mph
blackshine007 is offline
post #82 of 900 (permalink) Old 11-17-12, 0:20 Thread Starter
Quoted: 35 Post(s)
Garage
Still got some cleaning to do on this set of bowls but most the burrs are gone and I've opened up the channels to flow a little smoother by making the channels a little more smooth.... I feel like I'm getting way better and maybe even getting a little faster. If I can only figure out how to remove all that build up.
ID:	2487   Click image for larger version
ID:	2489   Click image for larger version
ID:	2490   Click image for larger version
post #83 of 900 (permalink) Old 11-18-12, 21:25 Thread Starter
Quoted: 35 Post(s)
Garage
here is a few threads I've been reading for those interested in pursuing porting on thier own head.
FS Head Performance Archive - ProbeTalk.com Forums
the team integra link and the msprotege link are really informative.
Cylinder Head Porting Mistakes - Engine Masters Magazine
post #84 of 900 (permalink) Old 11-21-12, 10:17 Thread Starter
Quoted: 35 Post(s)
Garage
Got all the material out of the exhaust ports. Now on to smoothing the rough spots and polishing the exhaust side and making it look pretty. Can't wait for my fsze intake to arrive.
ID:	2495   Click image for larger version
ID:	2496   Click image for larger version
ID:	2497   Click image for larger version
ID:	2498   Click image for larger version
post #85 of 900 (permalink) Old 11-23-12, 20:44 Thread Starter
Quoted: 35 Post(s)
Garage
I was told by the guy helping me with this that the intake side is done and the exhaust is pretty close aside from "polishing". He said don't worry about the rough look in the intake port.
He told me then to work on the combustion chamber by removing the step you can see and smoothing it then putting a small radius on the spark plug hole and making the valve seats flush with the top of the chamber. I may not do the latter because I sure don't wanna mess up the valve seats and be shit out of luck on all this work.
ID:	2502   Click image for larger version
post #86 of 900 (permalink) Old 11-30-12, 15:31 Thread Starter
Quoted: 35 Post(s)
Garage
No manifold for me. I got banned from the seller pending an eBay investigation of me apparently violating rules. I don't know what I did wrong. Anyways gonna get intake and tb spacers around Christmas and possibly a 98+ 626 manifold instead port that and start on reassembly. Need to get the head decked .010" and a valve job. I did get it cleaned although my dishwasher was a bitch to clean and sanitize after! Don't do that... lol
post #87 of 900 (permalink) Old 12-12-12, 0:40 Thread Starter
Quoted: 35 Post(s)
Garage
Picking up a stock 93 intake to port tomorrow. Gotta start looking into getting a now fuel pump. Price soit a valve job and head resurface and looking between $180 Andy $280 to get done. Then $120 for a head gasket kit and $80 for a cosmetic head gasket. So close to getting in. I'm gonna also get intake and tb spacers for Christmas from jayracing or outlaw engineering. Next week I'm also putting in the exhaust cam on the intake side.
post #88 of 900 (permalink) Old 12-13-12, 16:41 Thread Starter
Quoted: 35 Post(s)
Garage
Picked this up for $35 with iac, tb, fpr fuel rail and injectors! Looks like I get to start porting again!
post #89 of 900 (permalink) Old 12-13-12, 18:50 Thread Starter
Quoted: 35 Post(s)
Garage
I'm gonna do the egr block off on this manifold. It looks like the egr is a huge contributed to gumming things up. It'll keep my engine cleaner and since I don't have emissions here I don't think I'll have to worry. One port done. When I finish this I'll move on to hour glossing the throttle body. I'm getting a lot better and much faster!
ID:	2507   Click image for larger version
ID:	2508   Click image for larger version
post #90 of 900 (permalink) Old 12-14-12, 11:42 Thread Starter
Quoted: 35 Post(s)
Garage
And "done" about 2.5 hours and the manifold is matched for the head. All of the openings are within .05" of another. Not bad for a noob.... with some care I can get them perfect. I have a pair of mititoyo calipers by the way. Otherwise I'd just be eyeballing it and that wouldn't get me very far.
