Gauges not working - Mazda MX6 Forums: MX6 Forum
Old 5-7-12, 3:04   #1 (permalink)
  Total: 10 Power: 2
Gauges not working
so i did the klze swap from mx6 klde,the engine runs fine but my heat gauge goes rite across to the hot side and my rev counter and speedo not working. any ideas what could be the cause,i changed the sensor but it still doing the same thing......???????
balie is offline   Reply With Quote
Old 5-8-12, 10:06   #2 (permalink)
  Total: 433 Power: 5
PaulG's Avatar
Check if you forgot to hook up a ground under the hood.
1997 MX-6 LS
Old 5-9-12, 5:38   #3 (permalink)
  Total: 10 Power: 2
there are 3 that i hooked up,1 on the cam side engine mounting,1 on the gearbox and 1 coming from the starter. am i missing any other that i cant see?and wot do i do with the 1 wire knock sensor as im still running a-spec ecu with 2 wires?
Old 6-17-12, 2:51   #4 (permalink)
  Total: 10 Power: 0
Where do you earth the heat gauge cause mine is also not picking up, although i have found the earth wire ....
SA93MX6 is offline   Reply With Quote
