moisture problem, or something else? - Mazda MX6 Forums: MX6 Forum
Old 11-28-12, 11:43   #1 (permalink)
  Total: 1951 Power: 6
Zach's Avatar
Replaced alternator last night, but this symptom didn't show up until this morning.
88 626 4WS Turbo Noble White
97 626 LX V6 Timberline Mica
Email me for a turbo rebuild!
Old 11-28-12, 12:38   #2 (permalink)
  Total: 480 Power: 5
Your vid sucks. lol. What exactly are the sparks happening between?
My first guess is your engine doesnt have a good enough ground. But thats just a random guess without knowing exactly where the sparks are from, and too.
Old 11-28-12, 12:59   #3 (permalink)
Zach's Avatar
the arc is happening from idler pulley to crank on the rear bank side, just above the power steering tensioner
Old 11-28-12, 13:15   #4 (permalink)
  Total: 480 Power: 5
Id try tossing a large ground on the motor and see if that does anything. Im sure you have some random 4 gauge laying around. Dont even do it pretty, just toss it on and see if that stops it. If it does, then worry about it looking nice.
Old 11-28-12, 13:29   #5 (permalink)
Zach's Avatar
after I pulled out of the driveway, it stopped arcing...it was weird.
I'll see if it does it again today when I leave work.
Old 11-28-12, 16:35   #6 (permalink)
  Total: 29 Power: 2
I agree with MonoxideChild. Inspect your grounds. Gotta be a corroded grounding wire somewhere.
Old 11-28-12, 19:09   #7 (permalink)
  Total: 765 Power: 5
That ground you see in the video, for the first 5 seconds, on the engine mount, looks bad.
Old 12-1-12, 18:22   #8 (permalink)
  Total: 29 Power: 2
From the angle it's hard to tell if that wire is even connected to the mount. There's so much rust around that mounting bolt that I'm inclined to agree with NickR. At the very least remove that mounting bolt and take an aluminum or brass bristle brush to the rust to clean away the rust and oxidation. Inspect and if necessary clean the grounding wire connection then reinstall and see how that works. If that doesn't fix it then it's a different ground causing the issue. For a spark that blue and the interval it's probably coming from a sensor trying to turn on/off like a solenoid control wire.
Old 12-1-12, 19:58   #9 (permalink)
Zach's Avatar
the spark is arcing from the powersteering tensioner pulley. This isn't a normal 12v spark. The ground is good, it's not rusted...just a bad video and the wire is a little bit dirty. My next tests are going to be trying to find to see if this is an AC power source that's causing it to jump.
For now, looks like possibly a diode is bad causing bad AC sine wave.
Old 12-6-12, 15:49   #10 (permalink)
  Total: 11 Power: 1
make sure the pulley isn't touching on the alternator or something..thats my best guess
klze93419 is offline   Reply With Quote
