KLZE chip - Mazda MX-6 Forum
post #1 of 5 (permalink) Old 12-1-12, 10:54 Thread Starter
Quoted: 1 Post(s)
KLZE chip
Hi all,
I will be running a full KLZE setup with the addition of Colt cams NA spec and millenia injectors. I have recently purchased the following chip to install on a KL01 ECU :
Ford Probe GT Mazda MX6 Klze ECU KL31 KL36 Chip | eBay
I don't know how this will workout with the new cam specs and injectors. I was looking into getting a chip from probinator but I can't contact him. Is there anyone else who does these custom chips?
greendemon is offline
post #2 of 5 (permalink) Old 12-1-12, 11:38
whiteboysmx6's Avatar
Check out xtremethings.com he does a chip and there are a couple of people here that run his chip
whiteboysmx6 is offline
post #3 of 5 (permalink) Old 12-1-12, 12:52
Why are you running millenia injectors? there the same size as your stock ones. There not an upgrade. The millenia S injector's flow more, but in a N/A application, you would actually be slower using them.
~Patrick~
http://www.pmx626.com/ Your all in one Probe, MX-6, 626 Search engine.
monoxidechild is offline
post #4 of 5 (permalink) Old 12-1-12, 17:29 Thread Starter
Quoted: 1 Post(s)
It's a millenia engine I converted to KLZE specs, that is why I am using the millenia injectors. I have heard it was bigger but I was guessing It shouldn't be a problem. I have access to the KLZE injectors but they aren't in the best condition and I'm not sure if they are even working.
But I don't understand how it will be slower with NA. It came stock with the 2.5 millenia, KLZE head and block with the KL01 cams. Is it that it won't work well with the colt cam NA specs?
post #5 of 5 (permalink) Old 12-1-12, 21:05
Engine's make the most power at the brink of lean. Adding xtra unneeded fuel will just flood out the engine, and it wont make as much power. Pretty basic rule of tuning. More fuel isnt a good thing unless you have the air o go with it.
~Patrick~
