Sensor on front of 2.5L MTX tranny - Mazda MX6 Forums: MX6 Forum
Old 12-31-12, 17:54   #1 (permalink)
  Total: 14 Power: 2
What is the sensor on the front of the Manual trans in a 2.5L with two wires coming out of it? It threads into the tranny. I thought It was the speed sensor at first.
natev8 is offline   Reply With Quote
Old 12-31-12, 18:13   #2 (permalink)
  Total: 27 Power: 3
friendsofdonr's Avatar
back up light switch... according to the wsm
http://www.mx6.com/forums/garage/1005
http://www.mx6.com/forums/2g-mx6-oth...ld-thread.html
friendsofdonr is online now   Reply With Quote
Old 12-31-12, 18:17   #3 (permalink)
  Total: 14 Power: 2
That's it, thank you. I should have checked on Alldata before I left the shop. No speedo, I'm guessing it's a loose connection on the cluster(hoping anyway).
Old 12-31-12, 18:21   #4 (permalink)
  Total: 27 Power: 3
theres a plug coming off the back in about the same area. try unpluging that and pluggin it back in. mine was pretty easy to get to. I had removed my egr and my speedo stopped working. I unplugged it and then plugged it back in and it started working
Old 12-31-12, 18:36   #5 (permalink)
  Total: 14 Power: 2
It will sometimes start working when I hit a bump. The car set for an extended period of time and I decided to get it back on the road. I replaced the friction gear springs over the weekend and now I just need to get the speedo working so I can drive it further than from my house and to work and back. I only live two minutes from work.
Old 1-1-13, 5:48   #6 (permalink)
  Total: 10 Power: 4
you need this, let me know if you want it .
j2k90 is offline   Reply With Quote
Old 1-3-13, 17:07   #7 (permalink)
  Total: 14 Power: 2
Well, my trip meter works. I'm assuming my Odometer works as well. I put it on the rack at work, put it in gear and messed around with the cluster. I was gonna test the VSS, but since the trip is working the VSS must be sending a signal. Looks like I need a speedo head.
