Feeling a little down on torque. What should I check? - Mazda MX-6 Forum
post #1 of 2 (permalink) Old 1-1-13, 9:59 Thread Starter
K, so I've a KLZE w/ probinator, 9lb fidanza flywheel, test pipe, HEI mod.
Recently it's been feeling a little bit lacking in torque. It isn't terrible, it's just not pulling like it did only a few months back. I recently added a CAI, that helped a little, mainly just bumped the power up a bit in the high RPM range.
I'm just wondering if anyone has had a similar, unexplained drop in power and worked out the cause?
I have replaced leads and plugs (NGK), run a fuel additive injector cleaner a couple of times, cleaned the throttle body and replaced the vacuum lines to the VRIS system, so they are working.
I have heard that the crank angle sensor can go, which allegedly doesn't kill the engine, just makes it run a little less advanced timing and thus less power. Can anyone verify this?
Thanks!
2g 626 GE w/ KLZE
Ferramic clutch, BC coilovers, 18" rims
nolethane front end and engine mount bushings
HID conversion
Rhaski is offline
post #2 of 2 (permalink) Old 1-3-13, 5:29
PaulG's Avatar
Quoted: 26 Post(s)
Power: 6
Maybe check for vac leaks...maybe O2 sensors are on their way out...fpr not regulating fuel pressure as it should...
1997 MX-6 LS
PaulG is offline
