mx6 second ecu?? - Mazda MX-6 Forum
post #1 of 11 (permalink) Old 1-12-13, 11:55 Thread Starter
mx6 second ecu??
Hi all, my 2nd gen mx6 came with a kf 2.0 engine with external igniter and that engine died. I'm in the process of swapping it with a kl2.5 the engines we get there in Trinidad are from japan so i'm guessing its a klze. I got the engine and wiring harness however i am a little confused about the wiring. The jacks are different in addition the old harness has a second ecu that plugs into the harness with 2 black jacks its located behind the main ecu. Is that the transmission ecu or what?
krisjoseph_2000 is offline
post #2 of 11 (permalink) Old 1-12-13, 12:08
On sale's Avatar
You seems like very new to MX6 and ask for a very old impractical idea.
I4 for V6 will cost you a lot of headaches and trouble as you basicly need to swap the whole car except the chassis or the body.
In the US, getting a V6 is just from hundreds to $1500. It is better to sell you I4 and buy an old V6 for couple hundred then swap KLZE. Trust me, this will cost you way less than swapping I4 to V6.
There is a thread in this site and I guess only i person actually did it. However, it was done long logn time ago when the value of V6 was still around $5000.
Hope this help
My Rides: 08 750I, 01 740IL, 99 Z3, 93 MX6 GREEN, 96 3000GT VR4, 99 3000GT, 03 Eclipse GT
My Wife: 03 ML 350, 08 Kia Sedona
On sale is offline
post #3 of 11 (permalink) Old 1-13-13, 22:26 Thread Starter
Well maybe new but not totally ignorant. From my research i4 is a 4 cylinder engine my old engine was a kf v6 2.0 l and my new engine is a klv6 2.5l
old engine
Uploaded with ImageShack.us
new engine
new jacks
old jacks
Just a note my new kl has a coil and distributor in one and the old kf has an external coil
any help would be appreciated
post #4 of 11 (permalink) Old 1-14-13, 20:55
djdevon3's Avatar
Quoted: 2 Post(s)
Garage
Rewire the signal wire going into the external coil to go into the KL distributor. The distributor has 2 harness connectors on it while your KF likely only had 1. The extra connector on the KL distributor is for the wiring that would go to your KF's external coil. Now the bad news. Your external coil is going to send back a signal to the KF ECU that is different from the KL distributor. The resistance (Ohms) is going to be different and that might cause weak spark, no spark, or other issues. You've got a project on your hands now. Good luck.
djdevon3 is offline
post #5 of 11 (permalink) Old 1-14-13, 22:05
On sale's Avatar
Opps, that is why I am not sure where u come, as I assume u r the majority 2.0 which is I4
Here is the link, hope it will help u to finds ur questions. Base on what I have read so far, yes it will be a big project to you and it may end up the same result as my assumption in my first post. Nonetheless, good luck...............
Club323F • View topic - klze swap
On sale is offline
post #6 of 11 (permalink) Old 1-16-13, 3:42 Thread Starter
I have the two harnesses - the original kf and the one that came with the kl as well as the main ecu for both engines.so im trying some reverse engineering as well as the diagrams. I found out that its a different tcu that one uses and i can get it for about $80 usd. Tested where all the wires were getting signals from. I wired the main jack pcm power , start sigal etc yesterday which was the 7 wire connector, only a million more to go....... thanks for the links guys ill post my results soon
post #7 of 11 (permalink) Old 1-16-13, 9:15
TwoPedalWarrior's Avatar
Quoted: 48 Post(s)
krisjoseph_2000 - congrats on having the balls to do this.
1994 MX-6 LS ATX/MTX Swap
TwoPedalWarrior is offline
post #8 of 11 (permalink) Old 1-20-13, 17:05 Thread Starter
does anyone have the klze workshop manual? I have all the others but the klze color codes and pinouts seem to be different from the klde and I'm kinda stuck without it.
post #9 of 11 (permalink) Old 2-2-13, 13:33
On sale's Avatar
Any luck or update?
On sale is offline
post #10 of 11 (permalink) Old 2-2-13, 16:51
djdevon3's Avatar
Quoted: 2 Post(s)
Garage
You aren't stuck if you have a multimeter and a diagram of the DE distributor pinout which is likely the same as the ZE distributor. Gotta do some backprobing during cranking and you'll figure it out eventually. Yes it's going to be time consuming, tedious, and frustrating but you can do it that way. If you can find the start signal wire and hook that up then you have the skills to do the rest. You don't need an ECU pinout you just need to do a hell of a lot of backprobing.
djdevon3 is offline
post #11 of 11 (permalink) Old 2-5-13, 2:25 Thread Starter
Well for now since I needed to use the car I have pustponed the project. I ended up using my old harness with my old vaf, disty, ecu, external coil, and intake. The vris seems to kick in and the engine runs effortlessly even though I know it could run better with the original setup but I'm OK for now till I get my gearbox overtaking seems to be amazingly quick, I'm afraid of the kl for now.
