I hope someone can tell me what the rubber/plastic seal at the starter opening to access the flex plat bolts is called. I'm swapping the engine in my 2.0L 1995 mx6. The seal was very brittle. When I tried to slide it up and out, it broke. I believe it needs to go back in, otherwise there will be an opening where junk could get in. I've check at both the mazda dealership and the local auto parts store and no one seems to know what it is.
Basically this piece is about 1/8" thick x 1" high x 2" long. It is located right behind the starter. It had to be removed to get the bolts off the flex plat. If anyone knows where I could find one too, that would be great.
