New owner of a 94' Mazda MX6 - Mazda MX-6 Forum
post #1 of 21 (permalink) Old 2-21-17, 11:20 Thread Starter
Power: 0
Hello everyone,
Just few days ago my aunt gave me her Mazda MX 6 that she bought brand new in 1994. The car currently has 115k, it is a 5 speed V6 LS. Other than fading paint the car was taken care of to my aunts knowledge. All work was done at a Ford dealership with receipts saved. Now, to MY knowledge, she has done little to no work to the ignition, fuel, and air system of the engine. When I got the car and took it for a test drive, under load it has a pretty bad hesitation/stutter. Rev's fine, idles decent enough nothing crazy. So far I've replaced the plugs and the wires, still having the issue. What are some things I should look at, and maybe start replacing... it is a 23 year old car with 23 year old parts in most places.
jakobw5 is offline
post #2 of 21 (permalink) Old 2-22-17, 20:45
Quoted: 1 Post(s)
Power: 0
I'm in a similar situation with a 93. Since I don't know the history I plan to do the timing belt and anything else that could be changed while I'm in there. It's a bit of work to get at the belt so you may as well make sure the water pump, alternator and Pully bearings. Etc
Catimann is offline
post #3 of 21 (permalink) Old 2-23-17, 10:19 Thread Starter
Power: 0
I did notice that the shuddering only happens between 1500rpm to about 3000 rpm. After that it seems to smooth itself out!
jakobw5 is offline
post #4 of 21 (permalink) Old 2-23-17, 20:33
Quoted: 1 Post(s)
Power: 0
Clean the MAF
Catimann is offline
post #5 of 21 (permalink) Old 2-23-17, 22:07
TwoPedalWarrior's Avatar
Quoted: 48 Post(s)
Originally Posted by Catimann View Post
Clean the MAF
Silly boy, there are no maf's stock in these v6 cars.
If you've not done the cap and rotor do those, if issue still doesn't go away, its likely the distributor
1994 MX-6 LS ATX/MTX Swap
TwoPedalWarrior is offline
post #6 of 21 (permalink) Old 2-23-17, 23:00
Quoted: 42 Post(s)
Power: 3
Garage
[quote=
if you've not done the cap and rotor do those, if issue still doesn't go away, its likely the distributor[/quote]. +1?????
MaZZZda is offline
post #7 of 21 (permalink) Old 2-24-17, 15:39 Thread Starter
Power: 0
Yeah I'm assuming the MAF he is talking about is this....
http://images.oreillyauto.com/parts/...420063-rit.jpg
But how you go about cleaning that is besides me. I will replace the cap and rotor and update as soon as its installed.
jakobw5 is offline
post #8 of 21 (permalink) Old 2-24-17, 18:02
Quoted: 3 Post(s)
Make sure the ignition is OFF. The VAF which is normally marked as JE02, is between the air box and the throttle body. Check that the plug to the VAF is not corroded, disconnect the plug and scratch the terminals with a knife/blade to clean them and spray some penetrating fluid into both ends. If the problem persists .. let me know.
17" ROH Adrenaline Alloy Wheels, Superchip (for hi-octane +12hp), Stainless steel scuff plates, Powerfolding jdm mirrors, Mazda 6 MPS brakes (front + rear), 929 brake master (mx6 reservoir), JDM headlights, Altezza tail lights, Modified stock radio/cd with line-out +amp, Sound deadened doors + rear quarters << massive improvement
gwq_uk is offline
post #9 of 21 (permalink) Old 2-24-17, 18:08
Quoted: 3 Post(s)
Make sure the ignition is OFF. The VAF which is normally marked as JE02, it is between the air box and the throttle body, it has a plug connected to it. Check that the plug to the VAF is not corroded, disconnect the plug and scratch the terminals with a knife/blade to clean them and spray some penetrating fluid into both ends. If the problem persists .. let me know.
gwq_uk is offline
post #10 of 21 (permalink) Old 2-24-17, 18:24 Thread Starter
Power: 0
Hello everyone, So I took a video of the engine codes I am throwing. Can someone please help me diagnose these?
jakobw5 is offline
post #11 of 21 (permalink) Old 2-24-17, 18:28 Thread Starter
Power: 0
From what I see, got these...
08- MAF sensor/circuit
117- ECT
23- Rear 02
24- Rear 02
Can someone double check me on that? And then tell me exactly what I should be looking for or replacing.
jakobw5 is offline
post #12 of 21 (permalink) Old 2-24-17, 18:37 Thread Starter
Power: 0
Pulled the plug on the VAF, no corrosion of any kind, everything looks clean.
jakobw5 is offline
post #13 of 21 (permalink) Old 2-24-17, 18:38 Thread Starter
Power: 0
jakobw5 is offline
post #14 of 21 (permalink) Old 2-24-17, 18:40 Thread Starter
Power: 0
jakobw5 is offline
post #15 of 21 (permalink) Old 2-24-17, 18:53
Quoted: 3 Post(s)
Take a look at this video..
it is not for an MX6 but the process is just the same.
gwq_uk is offline
