Clutch Replacement Dilemma - Mazda MX-6 Forum
post #1 of 9 (permalink) Old 2-28-17, 17:28 Thread Starter
Quoted: 2 Post(s)
Anyone change a clutch on a MX6 LS 93-96 ??? Got everything taken off but, for some reason the transaxle case will not come all the way off. Tried using a screw driver to help pry but, have only separated the transaxle about 3/4" inch from engine. Are they typically a pain in the *ss to remove meaning that it needs to be wedged off??? The reason I am replacing the clutch is by because clutch was squealing with the clutch pedal pushed in and RPMS dropped sometimes to the point of Killing the vehicle. I believe the cause is a bad throw out bearing. Anyhow please help!!! How do i separate the transaxle to access the clutch assembly?? It acts it's binding on the splined shaft. PLEASE HELP!!!!
tripleshotmocha is offline
post #2 of 9 (permalink) Old 2-28-17, 18:25
Quoted: 3 Post(s)
I've never done it, but this thread may help: https://forums.probetalk.com/showthr...p?t=1701166624
(It's for the Ford Probe, but is mechanically almost identical.)
NickR is offline
post #3 of 9 (permalink) Old 3-1-17, 15:09 Thread Starter
Quoted: 2 Post(s)
Yes i saw that post. Thank you but, it doesn't get into detail if the transaxle won't free up. Just says use a wedge or screw driver for a stubborn contestant. I did not take the starter off which that post didn't say you had to do for the 2.5L V6. I'm just wondering if the starter not being unbolted may be why it won't come off all the way or the throw out bearing is binding up somehow????. In anyone with ideas it would be much appreciated!!!!
post #4 of 9 (permalink) Old 3-1-17, 15:58
Quoted: 61 Post(s)
Remove the starter.
— Jeremy Clarkson
concealer404 is offline
post #5 of 9 (permalink) Old 3-2-17, 18:42 Thread Starter
Quoted: 2 Post(s)
No luck with removing the starter. Wooden wedges maybe ?
post #6 of 9 (permalink) Old 3-2-17, 22:30 Thread Starter
Quoted: 2 Post(s)
The throw out bearing was making a bunch of squealing noise when pushing in the clutch. Does anyone think that the throw out bearing may be binding? If so what would be the remedy? I believe it's the original clutch. 275,000 on this little jewel. Come on experts help me out. Please!!!!!!
post #7 of 9 (permalink) Old 3-3-17, 13:16 Thread Starter
Quoted: 2 Post(s)
The article said I should have to take the passenger drive axle apart which is still in the transaxle casing. It suppose to slide out is that correct or should it be pulled out of the transaxle too?
post #8 of 9 (permalink) Old 3-6-17, 15:34 Thread Starter
Quoted: 2 Post(s)
Clutch nightmare!! !
In the middle of a clutch replacement on my 94 MX6 LS and stumped. All bolts and wiring are free but, the Transmission casing won't separate completely from engine. Currently it's about 1/4" spaced from the engine and won't slide off. I'm wondering if the input shaft is binding on on the pilot bearing or the clutch plate. I've tried prying it out, using a rubber mallet and wooden wedges but won't budge any further. This is a royal PITA. Can anyone give me some advice on how to get this stubborn contestant off????
post #9 of 9 (permalink) Old 3-6-17, 17:41
Quoted: 3 Post(s)
Sorry I can't help you. Maybe try asking on ProbeTalk, to see if anyone there might know?
NickR is offline
