1996 mx-6 randomly wont start - Mazda MX-6 Forum
post #1 of 9 (permalink) Old 3-18-17, 6:26 Thread Starter
Power: 0
I have a 1996 mx-6 4 cyl that randomly turns over but wont start. Then it will start right away. Came home it stalled. By the time i got son out to push it it started right up. Started 1st thing in morning then died in parking lot 5 minutes later and wouldnt start. Rolled Back into parking space and waited about 5 minutes and it started again. Drove home and came out 1.5 hours later and wouldnt start. In the afternoon it started right up. An hour later started up again. Drove to gas station and filled tank that was really really low and then it wouldnt start again. Tried throught the next day and a half with no luck. Turned over seemed to crank a little fast every time that it wouldnt start. Ended up pushing it home and ordered a fuel pump. Went out and tried again while we are waiting for fuel pump to be delivered and it started right up 7 times in a row. Let it run until warm and shut off and it started again. Afraid to go anywhere. Any clue in what. We should try?
JandM2015 is offline
post #2 of 9 (permalink) Old 3-18-17, 16:01
Power: 0
i got the same problem
same problem but mine want start at all now, is it the coil pack?
mazada man is offline
post #3 of 9 (permalink) Old 3-18-17, 19:49
Quoted: 8 Post(s)
Power: 2
Check your ground wires to the chassis and the connections to the starter
Somedoode is offline
post #4 of 9 (permalink) Old 3-18-17, 19:54
Quoted: 8 Post(s)
Power: 2
Sorry I need to learn to read. Ignore me lol
post #5 of 9 (permalink) Old 3-22-17, 5:44
PaulG's Avatar
Quoted: 26 Post(s)
Power: 6
It's usually the distributor that's the problem if you have no spark in the instances where it doesn't start. You can buy a new one, or look into the HEI mod.
1997 MX-6 LS
PaulG is offline
post #6 of 9 (permalink) Old 3-26-17, 1:28
Power: 0
new coil still no spark
any ideas
post #7 of 9 (permalink) Old 3-26-17, 18:04
Quoted: 3 Post(s)
I have ordered a crankshaft position sensor, from amazon, it seems the most likely cause of my NO START (my 2nd mx6 - I have both)! This issue would also have no spark. As the ECU WILL NOT want to ignite fuel when the crankshaft position is unknown!! The symptoms are that it starts occasionally. Cross fingers! About 30 of your dollars or pounds!
17" ROH Adrenaline Alloy Wheels, Superchip (for hi-octane +12hp), Stainless steel scuff plates, Powerfolding jdm mirrors, Mazda 6 MPS brakes (front + rear), 929 brake master (mx6 reservoir), JDM headlights, Altezza tail lights, Modified stock radio/cd with line-out +amp, Sound deadened doors + rear quarters << massive improvement
gwq_uk is offline
post #8 of 9 (permalink) Old 3-27-17, 11:55
Power: 0
you got 2.0 4 cylinder
post #9 of 9 (permalink) Old 4-15-17, 3:13
Quoted: 3 Post(s)
Mine had exactly the same issues.. FIXED!!
Please see this; ErgonITe - Probe/626/MX6 FAQ - Problem Areas
Part (inside distributor):
SPECTROMATIC LTD: J888 ignition module MAZDA MX-3
I bravely took my distributor apart whilst it was on the car, as I did not want to disturb the timing, it could only be taken apart and put back one way.
Here is a handy diagram. ie. #13 in the diagram
Click image for larger version
Name:	distributor assembley 2.jpg
gwq_uk is offline
