ignition problem!!quick response needed!! - Mazda MX6 Forums: MX6 Forum
Old 7-19-03, 14:07   #1 (permalink)
sammy82
i bought my mx6 4 cyl exactly a week ago...and last sunday(3 days after it was bought) the ignition decided to uit on me...the starter motor is rollin...but the engine isnt catchin...we checked plug #1 and #2 and both arent firing...the cap and rotor were newly replaced...so im guessing its the ignition module...but i dont want to buy it without much thought be cause it will set me back $310 ($360 - $50 for old module) and there are of course no refunds...i asked jus in case
ive been searching the net and this forum for a reasonable answer but havent seemed to reach a sensible conclusion...ive read alot of your posts about the msd igntion system...but was wondering if that can replace the ignition module...or is that just a bolton to the original module???
sorry for the long post and please give me som answers!!!
Old 7-19-03, 15:01   #2 (permalink)
hi, i am just trying to replace the transistor in the ICM, if it works, i will tell
iglitare is offline   Reply With Quote
Old 7-19-03, 19:20   #3 (permalink)
sammy82
we checked the rotor and its spinnin...
checked the wires...grounded them and theres no spark...on all four of them....
so we just took off the ignition module...
and i think we're jus gonna get the whole thing replaced...
mazda parts store is closed today...so i guess we'll have check it out on monday
is there anything else we should check out before spending a good $300????
thanks
Old 7-19-03, 21:18   #4 (permalink)
ohm the coil, check to see if the PCM is commanding the coil ground, check to see if the disty is sending the signals it should to the PCM... do you have any codes?
--97 S-10-- V8 Swapped project truck
--2002 Nissan Maxima-- Grocery Getter 5000
--91 Maxima-- Bone Stock Beater
1993 MX-6... Sold
Stage36 is offline   Reply With Quote
Old 7-20-03, 22:38   #5 (permalink)
sammy82
whoa whoa whoa~~~
PCM?codes??
unfamiliar territory.....
hmmm.....
i thought it went...crank sensor~>ECU~>ignition module~>disty~>spark plugs......
hmm...could u explain?sorry...im a lil slow...
Old 7-20-03, 23:04   #6 (permalink)
4 cyls dont have a crank sensor... we have 2 cam sensors...
anyway, the hall effect transistors in the disty send cam and crank position information to the PCM, the PCM, by way of the igniter driver grounds the coil inside the disty at the dwell point and then opens it at the time (specified by the ignition curve, programed in the PCM) in degrees when the spark should be fired. the opening of this transistor causes the field in the primary coil to collapse around the secondary coil and induce a voltage, usually between 5 and 15 kV at idle. the disty delivers the voltage spike to whichever cylinders respective disty cap electrode is closest... fire
1993 MX-6... Sold
Old 7-21-03, 0:15   #7 (permalink)
sammy82
thanks for the quick reply man...
now after i translate ur reply...ill try it out on my car
dang...i really need to take a class in automotives.......
