My clutch sticks! - Mazda MX6 Forums: MX6 Forum
Old 7-25-03, 2:45   #1 (permalink)
Xplicit_Six
My clutch sticks!
I was racing a vtec lude tonight and after each time I'd shift, (just in 2nd and 3rd), my clutch would stick and would stay at the rpm I shifted at for a second or two and then finally drop back down. Like it wouldn't catch the gears immediately.This is really hard to explain. But if anybody could help me, that would be great.
Old 7-25-03, 14:02   #2 (permalink)
  Total: 334 Power: 5
Mr. MX6's Avatar
well is sounds like your culch is slipping .. I.e. worn out.. could be time for an upgrade..
If you aren't living on the edge...Your taking up to much space..
Mr. MX6 is offline   Reply With Quote
Old 7-25-03, 20:46   #3 (permalink)
Xplicit_Six
No, I really don't think it's slipping. It's hard to explain. If anybody has any other ideas please let me know.
Old 7-25-03, 23:27   #4 (permalink)
  Total: 66 Power: 5
i think i know what you're talking about... mine's been doing the same thing but only once in a while, it hasn't given me any real problems though so i wouldn't worry too much about it yet.
speedyLS is offline   Reply With Quote
Old 7-28-03, 22:40   #5 (permalink)
No, seriously. that sounds like slipping ot me...
--97 S-10-- V8 Swapped project truck
--2002 Nissan Maxima-- Grocery Getter 5000
--91 Maxima-- Bone Stock Beater
1993 MX-6... Sold
Stage36 is offline   Reply With Quote
Old 7-28-03, 23:50   #6 (permalink)
I have the same problem too. Mine seems to be stuck in 2 when I tried to upshift. But other gears work fine though. Is it because of low fluid or something else that I don't know?
richardsjmx6 is offline   Reply With Quote
Old 7-29-03, 0:22   #7 (permalink)
when you say stuck, you mean it wont go into gear, wont gcome out of gear? what?
you can check the fluid level by parking on a level surface and pulling out the fill plug (23mm). the fluid level should be to the bottom of that bore. if not, top it up.
let us know how it goes...
1993 MX-6... Sold
Old 7-29-03, 0:34   #8 (permalink)
Thanx Stage36! I meant stuck because it seems like it's harder to shift out of it, as if it stuck there. Using extra force, I can shift but it only happens with 2nd gear.
Old 7-29-03, 2:25   #9 (permalink)
joeyjordison24
try replacing the clutch...while youre at it replace the pressure plate and throwout bearing. shouldnt cost more than $150. i replaced all that and its done wonders for my 6. peace.
Old 7-29-03, 5:25   #10 (permalink)
Xplicit_Six
It rarely does this. But when it does, it does it when I'm racing and shifting fast.
Old 7-29-03, 5:29   #11 (permalink)
same thing happened to me.. your clutch is worn out..
it stays at just over 5k, then goes down and grips and starts rising right? and u cant chirp into 2nd anymore..
i just replaced my clutch and now its all good...
SilverLS is offline   Reply With Quote
Old 7-29-03, 16:19   #12 (permalink)
Xplicit_Six
That's exactly what I'm talking about. But, the b*tch that sold me the car *SAID* the clutch had been replaced. I guess not
Old 7-29-03, 21:37   #13 (permalink)
YEAH!!! lets just throw parts at it!!! while youre at it, replace the taillights and the headliner too!
does the car sorta 'jerk' as you pull it out of gear? this could be a bent linkage or something internal. i know you dont wanna hear that but... describe it a little further...
she probably did, but when you were racing on it, you managed to put some hotspots on the flywheel and PP and caused it to lose its efficiency. this would make sense because you also say it happens when you race (i.e. when you heat it up).
1993 MX-6... Sold
