Follow up to shaking Sixes - Mazda MX6 Forums: MX6 Forum
Old 8-1-03, 23:00   #1 (permalink)
  Total: 19 Power: 5
I hate how my car shakes. There are a few things I'm fixing to get ride of the shaking, 1) Broken spring 2) Rear brakes 3) Engine mounts
Anyways, this Consumer Guide has a few trouble spots listed for the 2nd Gen six.
Here it is. And here's the link
http://auto.consumerguide.com/auto/u...fm/id/2067.htm
Trouble Spots
Engine knock: Cars with a V6 engine built before March 1993 may have engine knock, especially when cold, due to carbon buildup in the combustion chamber. (1993-94)
Engine mounts: Broken motor mounts allow the engine to rock back and forth when accelerating, decelerating, or starting from a stop. (1993-94)
Engine noise: A metallic tapping noise from the rear of the engine could be due to slippage between the exhaust-camshaft driven gear and friction gear. (1993-95)
Power seats: The insulation on the wires for the power seat can wear through causing a short circuit. (1993-94)
Transmission leak: A damaged torque-converter hub seal allows fluid to leak from the automatic transmission. (1994-96)
Vehicle shake: Vibrations in the steering wheel, shift lever, and floor are probably caused by mispositioned radiator dampers. (1993-95)
Wipers: The welds holding the wiper-arm support bracket break, causing a creak or rattle when the wipers are running. (1993-95)
As you can see, the "mispositioned radiator dampers" has me boggled, does anyone have any clue as to what this is all about?
clean and fast
Maksymuik is offline   Reply With Quote
