what does the oil sending unit do? - Mazda MX-6 Forum
post #1 of 16 (permalink) Old 11-22-03, 13:33 Thread Starter
I believe I have a bad oil sending unit. I was just wondering what it actually does. Thanks alot.
Ryde _Or_Die is offline
post #2 of 16 (permalink) Old 11-22-03, 14:30
It's just a switch for the oil pressure light on your dash. When it senses dangerously low oil presssure, the light comes on.
mts3 is offline
post #3 of 16 (permalink) Old 11-22-03, 19:18 Thread Starter
So basically there are no ill effects to the engine/etc unless I get really low oil pressure because I won't know it?
post #4 of 16 (permalink) Old 11-22-03, 19:54
The Full Dong
Radar's Avatar
yep...oe u may also get a false oil light
Turbo KL 400whp/407tq - SHAODOME @ PROBETALK
Successfully Megasquirted: 94 MX6-ZEt, 92 MX3 ZE, 94 MX6 LS, 96 PGT ZE, 96 PGT w/ every bolton, 93 PGT, 93 PGTZE, 95 PGT ZE, Celica GTS built 20v-turbo, 95 PGT, 97 PGT ZE, 97 MX6 KLZE, 97 PGT w/ botlons, Mazguy's Built MX-6 Turbo, 97 Mustang V6 EDIS, Delorean with a T70 Turbo, and a 87' Built 1.8t VW Golf (25psi),97 SE-T. No more sig space
Radar is offline
post #5 of 16 (permalink) Old 11-23-03, 16:36
it can/will leak oil, i had to replace mine, cheap and easy to fix.
CRiZO is offline
post #6 of 16 (permalink) Old 11-23-03, 16:57 Thread Starter
Where is it exactly?
post #7 of 16 (permalink) Old 11-23-03, 20:30
On the V6, from under the car, find the oil filter. Then look right above that. It will have a wire (maybe 2) going to it.
mts3 is offline
post #8 of 16 (permalink) Old 11-24-03, 8:53
Mr. MX6's Avatar
Its cheep replace it if it is faulty .. It will only let you down later by dripping out oil all over the place.. And it is doing a very important job by monitoring your oil pressure..
As he said just above the oil filter .. it is a hexagonal nut looking thing.. wit one wire coming from it ..
You will require large socket or ring spanner to remove it… but it only takes a min.
Mr. MX6 is offline
post #9 of 16 (permalink) Old 11-24-03, 15:32
Ruubstr94Ls's Avatar
Yep. Another reason why its great to have aftermarket gauges, so you can read things 'accurately'.
2011 Toyota Camry 6MT
Ruubstr94Ls is offline
post #10 of 16 (permalink) Old 1-9-04, 14:47 Thread Starter
I've read in other people's posts that it can cause a knocking from the engine. Is this true?
http://www.mx6.com/forums/showthread...t=quiet+engine (Oil Leak + Knocking sound from engine)
post #11 of 16 (permalink) Old 1-11-04, 14:04 Thread Starter
bump
post #12 of 16 (permalink) Old 1-12-04, 12:06 Thread Starter
Anyone?
post #13 of 16 (permalink) Old 1-12-04, 13:29
What he heard wasn't knocking, but ticking. Higher pitched than a knock, but as you probably figured out, he wasn't real familiar with car terminology. So he blindly called it knocking.
What the noise is caused from are the lifters. They need LOTS OF OIL to stay cool and to cushion the blow of the cam(s).
It was from his oil level getting low, not because of the sending unit. Well, the sending unit was leaking so yea..... it was "technically" caused by the sending unit.
My wife isn't very religious about checking her oil, and with 190K miles on the engine, she NEEDS TO CHECK IT.
One day I drove it to work and about half way there I had rolled down the window to catch a breeze. With the window down I could hear those poor little lifters getting the crap beat off of them.
I checked the oil level and sure as hell, it was 2 qts. low. Once I added the oil the noise stopped.
Save a Cow
Eat a Vegetarian
drvITlīkUstōlIT is offline
post #14 of 16 (permalink) Old 1-12-04, 17:19 Thread Starter
Alrght thanks. Ya I changed my OSU and oil and had 2 things of stuff to quiet lifters and valves in there for a few days and they are just about silent. Now the only noise I have is the one coming from the power steering pump/pulley. Is there a way to turn off the power steering? So that if I didn't have any fluid in there it wouldn't mess anything up? Thanks for the help.
post #15 of 16 (permalink) Old 1-12-04, 17:38
hehe, if your running your car and that low oil pressure light turns on....your already screwed.
im back....and resurrecting my mx6. she has been sleeping for 6 years, and she is angry....
SolarSlash is offline
