running problem - Mazda MX6 Forums: MX6 Forum
Old 2-16-04, 19:02   #1 (permalink)
running problem
hii have a 93 ford probe 2.0 and the last couple of days it has been acting up first it started cutting out while going around turns then that stopped and then it started doing it along stright stretches then all the time then after it would have a really hard time starting in the mornings then when it did start the same thing would happen but let me explain this if you give it gas really easy just enough to the point that it would keep a slow pace like just resting your foot on the gas it is fine but if you give it more it starts bogging really bad off and on when it wants to it will idle fine except every couple of minutes you can hear it bog once or twice now this is what i replaced the plugs the wires disty cap and rotor ignition coil, fuel filter, air filter , purge solenoid,maf sensor, and i have a self code reader i got from wal-mart and it doesnt give me any codes well it did for the pure solenoid but i fixed that my guess is the throttle posistion sensor but im not sure maybe even the fuel pump acts up every now and then i dont know......... if any one could help i would appreciate it thanks
ironmanhiggs is offline   Reply With Quote
