Old 3-30-04, 15:39   #16 (permalink)
  Total: 65 Power: 5
I went to go replace mine today, however the ones under my gearstick were just fine. It's actually the bushings near my transmission that need to be replaced, another weekend job. If the bushings are in there tight and look to be doing their job, DONT TRY TO RIP THEM OUT. That will just cause a lot more problems than it's worth!
Help me get a free ipod, and get yourself one while you do it! This is ACTUALLY A LEGIT DEAL! Check it out here
Rivulent is offline   Reply With Quote
Old 3-30-04, 18:07   #17 (permalink)
buckleyheaven
can some post the pictures or host them someplace else or even email them to me at ozmojo1@hotmail.com because I really need to do this and I really need the pictures. Thanks, Rory
I'm with you oxmojo on this one. Really need the pics. If someone could post the links or even email me the pictures on jpham@alphalink.com.au that would be veryu much appreciated. thanks thanks thanks!!!!!!!!!
Old 3-31-04, 3:59   #18 (permalink)
  Total: 16 Power: 5
man it's simple. put the car on a hoyst or if you dont have one as high as you can on ramps etc.
and just undo the 1 bolt under the gear nob, and replace the two plastic ends,with new ones,(or push with a screw driver whatever is left of the old ones out) that's it. i did it without removing the exaust shield just flex it when puting the 10mm in there(but it's easier without it ofcourse)
don't lube nothing. (and don't over tighten , will be hard to move the gearstik after) (from own experience).
The End
hope jasonius (buddy) dosn't get cranky for barging in,(fix the pix bro)
pupchick is offline   Reply With Quote
Old 3-31-04, 14:19   #19 (permalink)
  Total: 81 Power: 5
ozmojo, i am doing the same instal soon, i will take some pics of mine.
93' blue MX6 , anything and everything modified
head of something in NESO
aka "deep pockets"
1 low mx6 is offline   Reply With Quote
Old 3-31-04, 15:31   #20 (permalink)
  Total: 265 Power: 5
thanks- rory
ozmojo1 is offline   Reply With Quote
Old 3-31-04, 22:50   #21 (permalink)
  Total: 65 Power: 5
I personally was not able to get the plastic seals out of it, which tells me they are still good and tight. Even with a screwdriver, needlenose pliers, nothing.
Old 4-1-04, 4:00   #22 (permalink)
  Total: 16 Power: 5
man if you bought new one's change them,(if you have play ofcourse)
try harder, pushin the old one out (should be more like pull them out (if they aren't all that damaged yet))
Old 4-1-04, 19:11   #23 (permalink)
Bi-xual and ZE-curious
  Total: 128 Power: 5
CardinalBiggles's Avatar
Pics have been unavailable because Caleb's uploader has been down (Uploading Images.). The thumbnails are back (thanks Caleb), but the bigger pics are now available as well for those who wanted them. I'll edit out once Jase's updated the main post:
/X\azda Pride - - Mixy & Trixy the Fazda Twins!
CardinalBiggles is offline   Reply With Quote
Old 7-31-04, 5:18   #24 (permalink)
blues-harp
Originally Posted by chaddy
Will replacing the bushes help stop my car popping out of 5th gear?
No, I don't think so at all.
Old 8-6-04, 7:38   #25 (permalink)
nothing better than a nice tight box... !!
bigirish is offline   Reply With Quote
Old 8-6-04, 8:58   #26 (permalink)
  Total: 26 Power: 5
How much do they charge for these bushings? And do they need to be bought at a MAzda dealer?
Metman is offline   Reply With Quote
Old 8-6-04, 12:47   #27 (permalink)
  Total: 1095 Power: 5
Ruubstr94Ls's Avatar
Yes you can get them at Mazda. I paid $3.60 a piece for mine, and installed them and they made a big difference, alot tighter shifter and side play is very minimal.
Ruby's Mx6
94 Mx6 LS 2.5L Hunter Green: Get your OWN style!!
AIM: Ruubstr94Ls
Ruubstr94Ls is offline   Reply With Quote
Old 10-2-04, 15:04   #28 (permalink)
different bushings (apparently)
Hello all,
I'm a first time poster, and I figured I would share my experience with changing my bushings.
After I realized I needed to change the bushings I searched the forum for help. Then found this thread. (Which is awesome by the way.) So I ordered my parts (46-062A) and set out on the weekend to change them. After a bit of frustration, I got the old ones off. BUT the old ones were much larger than the new ones I got. And after trying every which way, i decided that the new ones were NOT the right ones cause they don't fit at ALL. (Not even a little bit.) They are way tooo small. So I called both Mazda dealers in town, and both were closed. So then I thought I would try the ford dealer (since the probes are damn near the same), well the guy on the phone said he had the right ones. So I drove in (with my Trans AM, which is currenlty illegal, but the only car I had left to drive!), and got to ford. The parts guy gave me the bushings, and they are the same ones I got from Mazda! SO I did have the right ones, but they still don't fit. So now I'm lost! I don't know why the correct bushings aren't fitting, and I'm pretty sure all the shift linkage is stock (at least it looks like it), so I don't understand.
So now I put what was left of the old bushings back on, now my sloppiness in my shifter is even worse!! But I can find the gears fine, so I'm gunna try and go to mazda on monday and see what they can do.
Has anybody had a problem like this? (I was thinking of putting in a short through shifter just to bypass all these damn bushings.... but that's a lot more money just to by pass a 4 dollar bushing!)
-frustrated and out of ideas.
P.s. my car is a 95 mx-6 with a 4 cyc, and 5 speed manual.
mockler is offline   Reply With Quote
Old 10-5-04, 19:43   #29 (permalink)
MX6.com Supporter - Click Here for Information [RF]my bike=stupidly fast
  Total: 331 Power: 5
neptune_51's Avatar
all i can say is changing the shifter bushings at the tranny is a PITA!!! lots of swearing that night!!
2006 Honda CBR600rr - daily driver/rider and potential death machine
Originally Posted by neptune_51
Who would be stupid enough to quote themselves in a sig?
Old 12-15-04, 17:01   #30 (permalink)
Praise the ...lifted?
  Total: 355 Power: 5
esembe's Avatar
im having the exact same problem
here's the difference, even though the pictures SUCK
WHITE = OLD (probobly stock) ...had some different Bolt in there, wasn't as thick in the middle :/
GREEN = New Mazda Ones
i wonder why we had this problem, and what these 'wrong' bushings belong too :/
esembe is offline   Reply With Quote
