Green wire to tachometer lead - Mazda MX6 Forums: MX6 Forum
Old 5-14-07, 5:50   #1 (permalink)
  Total: 17 Power: 5
Hi,
i need to plug my New SDS EIC. the green wire need to be plugged to tachometer lead
but i need to find where i can plug this green wire.
i have a mx-6 LS 1994.
behind my cluster i have have 3 plugs... one with 13 pins, 12 pins, and 10 pins... i would like to know if someone can give me some information about where i can plug this green wire?
thank'S
dank
peperman is offline   Reply With Quote
Old 5-14-07, 6:20   #2 (permalink)
  Total: 19 Power: 5
the solid green tacho wire should be in the harness that is closest to the tacho in the cluster
92 Ford Telstar V6 KL-ZE: CAI, 17" Chromies, Sprayed Painted Interior, F & R Seat Covers, Lowered, Front Strut Brace, Manual Conversion! 2 Sony 15" Subs, Alpine 5x7's in da front, Alpine head deck, Response 2 x 380WRMS amp, HEI Mod with Blaster 3, White Face Gauges, 55watt 6000k HID's
Tx5guy is offline   Reply With Quote
Old 5-14-07, 20:14   #3 (permalink)
  Total: 17 Power: 5
thank you very much!
Old 6-1-07, 6:04   #4 (permalink)
  Total: 17 Power: 5
Humm sory i have look behind the cluster and i did not find any green wire in the harness that is closest to the tacho!!! no onw have any information where i can connect this green wire??? the harness on the ECU did not have this wire that i need????....if someone have connect a new aftermarket tacho... maybe can give me more information?
thank's
Old 6-1-07, 11:40   #5 (permalink)
  Total: 17 Power: 5
What i did was just run the wire straight to the disty. You can get a diagram of the ecu and tap into that. Going straight to the disty is just being lazy. If i was going to redo main i would go to the ecu.
to many mods to put down
fasthard is offline   Reply With Quote
Old 6-1-07, 18:45   #6 (permalink)
  Total: 17 Power: 5
direct tap to the wiring harness ecu (one wire, but which one is? ) ....Is the best way for me, because my SDS E.I.C. controler is near of the ecu. but i did'nt have the diagram ecu for the Mx6 LS V6 OBD1 (1994) . if someone have the diagram it could help me!
Thank's
Dank
Old 6-2-07, 9:31   #7 (permalink)
  Total: 135 Power: 5
Thank's
Dank
If you search on probetalk, they have a pinout for each year posted up somewhere, just search for "ECU wiring diagram" or "ECU pinout."
'96 MX-6 LS V6 M/T
ZE powered, OBD-I, M-Edition Wheels, Lots of Goodies...
'94 626 V6 LX M/T [R.I.P.]
'93 MX-6 ZE-V6 LS M/T [R.I.P.]
'93 MX-6 V6 LS A/T [R.I.P.]
snailman153624 is offline   Reply With Quote
Old 6-4-07, 5:22   #8 (permalink)
  Total: 17 Power: 5
on this link
http://home.comcast.net/~mmunoz70/z/ecupinout.txt
can i use the right connector pin 8 (on the Ecu) to run at my SDS EIC controler,
pin 8 is
Igniter output (aka Distributor Ignition)
thank's
