hey guys prob with 1993 mx6 - Mazda MX6 Forums: MX6 Forum
Old 6-20-07, 17:56   #1 (permalink)
ok i have a 1993 mazda mx6 v6 ok what it has done is i was driving down the street las week car just died like dead it will turn over np just wont start so heres things i have done to trouble shoot it switchted distys no luck that wasnt the problem plugs to the disty r ok checked all fuses but i think i found the problem but dont know where to look my floor lights r hooked to my switched power and i got no floor lights so hence i think i found my rpoblem which would give me no spark or fuel where would i begin to even look i got a parts car same car to switch parts so give me some advice to even 2 start looking thanks guys
spikedmike440 is offline   Reply With Quote
Old 6-20-07, 20:12   #2 (permalink)
  Total: 60 Power: 5
BOYZERO's Avatar
Try to be more specific. Does ot turn but no start. Start but dies. Clicks only, no noise or do u think u are not getting fuel?
93 MX6 LS,Boosted 6lbs,180 stat,udp,2.5in exhaust w/hooker aero chamber muffler w/3in tip,S2 clutch,11lb flywhl,strut bars,eibachs,monroes,awr f/r mm,awr sway bar kit,b&m shifter w/rr-racing&corksport brass bushings,. 1/4=15.0@92.5 n/a http://i215.photobucket.com/albums/c...lipboyzero.jpg-timeslip-stock cat,ecu,clutch/flwhl
Old 6-20-07, 22:26   #3 (permalink)
  Total: 411 Power: 5
run-on sentences FTL.
spikedmike440: what did you think the problem was?
from what you're saying, this sounds like a failed distributor, which is fairly common for the 93 & 94 cars.
yes, i read where you said you swapped distys, but have you considered that maybe the other one was also bad? what year is the parts car? have you confirmed that you're getting spark?
come on back and let us know what's going on.
damon™
1993 ford probe gt
1994 mazda mx-6 ls
2001 ford svt mustang cobra
dmark101 is offline   Reply With Quote
Old 6-24-07, 20:33   #4 (permalink)
i have confirmed it is getting spark this disty came out of a running car. far as turning over it turns over fine. it is like theres no fuel no spark. ive did a check for spark there isnt any. i have done a check for fuel there is none pump is not running. i know its the switched power. i asked where do i even begin to look when it comes to that lemme know guys. and thanks for the advice sorry for the run on sentences, i suck at grammer lol
