Old 9-11-07, 23:37   #1 (permalink)
  Total: 26 Power: 3
mflbrody's Avatar
Autozone
So I was in autozone earlier today and I saw that they had the parts to make a cold air intake (among other things), basically what I want to know is if I did that would I have a decent cold air intake? Also, are their other parts high quality.. the only reason I'm a little bit leary is because it's a chain store. Thanks
Tl;Dr
Are Autozone parts high quality?
mflbrody is offline   Reply With Quote
Old 9-12-07, 0:02   #2 (permalink)
  Total: 11 Power: 5
its higher quality than pvc piping i would think
toolerboy is offline   Reply With Quote
Old 9-12-07, 8:10   #3 (permalink)
  Total: 26 Power: 3
mflbrody's Avatar
well yeah i know that.. I just wanna know if it would be a higher quality intake then if I were to say, buy one from ebay or something.
Old 9-12-07, 9:10   #4 (permalink)
  Total: 112 Power: 5
It's going to be identical to the $200 Hot Shot intakes if you buy the right pieces and shape it right. The Big Key is buying a QUALITY filter. The Ebay junk filters aren't that good.
'93 MX6- [Tockico+Eibachs][.50/.63 Turbo][MSnS][17" Motegis][STRIPPED!]
'95 Probe GT -[Eibachs][Borla Exhaust][17" Enkeis][Limo Tint][DAILY DRIVER]
The Others - [BMW E36 325i][ '04 Nissan Sentra]
ExtremeJDK is offline   Reply With Quote
Old 9-12-07, 12:31   #5 (permalink)
  Total: 26 Power: 3
mflbrody's Avatar
ok.. so they have filters there too, are those quality filters or would it be a better idea to order and AEM or K&N one?
Old 9-12-07, 14:06   #6 (permalink)
  Total: 458 Power: 5
I wouldn't go as far as saying the quality is the same as a Hotshot. I know I might be biased since I have one, but I've also had the crap ebay one. The Hotshot is made of good quality SS, while the crap ebay one is made of some super thin pot metal that gets cloudy after three drives.
Agreed on the filter though. The quality difference between a true K&N and whatever the hell they give you with your ebay one is a big one.
Originally Posted by pearsonmx6
purple fuzzy turtles are going to take over the world
The King of Mexico
Shwaykid is offline   Reply With Quote
Old 9-12-07, 15:51   #7 (permalink)
  Total: 26 Power: 3
mflbrody's Avatar
sooo....? Autozone filter or sack up and buy a K&N?
Old 9-12-07, 16:09   #8 (permalink)
  Total: 458 Power: 5
I'd personally rather have a K&N. Those are designed to be cleaned with the recharge kit so I know nothing will happen when I clean it. After a lot of miles, I wouldn't be as confident if a knock off would start disintegrating itself.
The King of Mexico
Old 9-12-07, 19:18   #9 (permalink)
  Total: 107 Power: 3
not the cheap one,those filters rust...well not the filter,but the wire mesh will,which ruins the filter part. nut up and buy a lifetime warrantied product
99 SVT contour. msds headers and highflow y pipe,65mm throttle body,eibach springs & koni adjustable struts,k&n ru3530 cai,pgt fstb.
mxdriver is offline   Reply With Quote
Old 9-13-07, 2:07   #10 (permalink)
  Total: 1704 Power: 5
KING6's Avatar
Before my bro sold his GSX, he baught a bunch of that make your own intake crap from auto zone. He gotta maf translator wich required smaller intake tubes.
Basically, That whole DIY intake crap is all plastic. And its cheap. Dont waist time or money, the intakes you can get on ebay are cheap enough.
That plastic intake stuff isnt higher quality. PCV is alot stronger,and will resist more heat. Not to mention it wont melt if to close to something that gives off alot of heat.
Old 9-13-07, 9:43   #11 (permalink)
  Total: 335 Power: 5
whitenoyz's Avatar
What I did FTW:
http://www.mx6.com/forums/gallery/19...etty-good.html ($15 CAI, looks pretty good)
Be like me, the filter sits higher up now and i've driven through what were pretty much tropical storms
Old 9-13-07, 11:53   #12 (permalink)
  Total: 112 Power: 5
Originally Posted by KING6 View Post
Basically, That whole DIY intake crap is all plastic. ... That plastic intake stuff isnt higher quality. PCV is alot stronger,and will resist more heat. Not to mention it wont melt if to close to something that gives off alot of heat.
The stock intake is plastic. Going with an aluminum or steel tubing would gather way more heat to the incoming air. That's why I really wish the KL's manifold wasn't aluminum.
True, it's not going to be as durable as PVC, but honestly ... how many times has a correctly installed intake ever melted on a hot pipe. Probably never.
I'm not trying to argue or prove anyone wrong, just saying from personal experience they've worked great for me. here's what i did with the Autozone Pieces to run an air from my turbo. Not pretty but works.
Old 9-13-07, 18:24   #13 (permalink)
  Total: 26 Power: 3
mflbrody's Avatar
thanks for the tip on the PVC, but I think I'd rather stick with a metal of somekind and then maybe heat wrap it or something..
Old 9-14-07, 0:12   #14 (permalink)
  Total: 11 Power: 5
i had the ebay one on my car. it does the job just buy a different filter and an air bypass valve if you want. its only like $40
Old 9-14-07, 0:17   #15 (permalink)
  Total: 26 Power: 3
mflbrody's Avatar
ok, I have another question... I have a cf hood so I don't have the windshield washer nubs anymore... anyway. Does the length of the intake tubing matter because I'd like to take out the washer fluid resevoir and run the intake down through there to just behind the bumper. Basically would I be choking the engine or would it work ok?
