Old 5-3-08, 15:57   #31 (permalink)
  Total: 646 Power: 2
defiler's Avatar
There arent any 626 in the yards here that are newer than 97, otherwise I would go that route. But for some reason the Contour is in there...
89MX6 GT 4WS - Not stock... 135whp/170wtq@7PSI on blown VJ11
Old 5-4-08, 15:42   #32 (permalink)
  Total: 196 Power: 2
Just wanted to add that the 99+ protege with the FS 2.0 comes with an 18mm sway that is a direct fit.
It dosnt have that wierd bend in it that the skiny 1.6L bar has.
I did some more measuring and found that the mx6 and some 626's have the 26mm front sway and the probes and some 626's have a 28mm front sway bar.
All 2G probes I measured SE and GT had the 28mm bar and all 2g mx6's had the 26mm bar.
I measured several 626's and some had the 26 and some had the 28. It didnt seem to matter what year or engine it was. I measured 2 94 V6 cars and one had the 26 and the other was 28.
Both the 98+ 626's were 28mm however.
90 pontiac transam. 350 TPI motor new 24# injectors. That's all for now.
Old 5-10-08, 16:02   #33 (permalink)
  Total: 10 Power: 2
found 2 contour se's in the local "gold mine." No svt's.
One rear bar was 16mm the other was 18.5mm.
Picking it up Monday.
Oh Yeah!
L88888888
B
dabckid is offline   Reply With Quote
Old 5-13-08, 8:32   #34 (permalink)
  Total: 33 Power: 5
Originally Posted by 2old2zoomzoom View Post
I don't see why you couldn't use the Altima links instead of the RX7's. And the year of the SE is going to determine the bar size. I found a couple in the junk yard here that were 16mm, you might as well get a 626 bar if you go with 16mm, at least it'll be the proper length.
My pictures will show you why you can't use them nor the stock links, back on page 1. The angle that they will be sitting at will be too extreme and cause them to fatigue and fail very early. RX7 links>Altima links
Custom built hybrid mx3/626 shifter, chipped KLZE w/ DE valve springs and retainers, headers, full 2.5inch exhaust with test pipe, ram air, fidanza 9lbs flywheel w/ stage 2R clutch, PGT tranny with trans saver, PGT (eibach) suspension and driver seat, contour SVT rear sway bar.... need paint...
blackshine007 is offline   Reply With Quote
Old 5-14-08, 22:53   #35 (permalink)
  Total: 31 Power: 2
what year rx7 links? 1st 2nd or 3rd gen? cause ill order new ones and grab the csvt bar from pull a part if i can find one.
darkmushroom is offline   Reply With Quote
Old 5-17-08, 6:45   #36 (permalink)
  Total: 33 Power: 5
^^Second gen.
