Old 3-4-08, 2:37   #1 (permalink)
  Total: 10 Power: 4
tune up suggestions
Hi guys. I own a 94 mx-6 2.0L Can I get some recommendations on a high performance distributer , cap and wires, and also what spark plugs do you guys use to get maximum performance out of your ride? Thank you, just trying to keep the baby running sweet.
temag is offline   Reply With Quote
Old 3-5-08, 21:30   #2 (permalink)
  Total: 16 Power: 5
NGK iridium plugs run very well, replace the rotor inside the cap as well, the distributor wont do a lot for for you unless yours is bad but there should be a module inside the cap that could build resistence so its worth replacing for the cost. the wires are important as well as the routing find some 8mm and be sure they dont lay across metal or eachother.
seansjspecmx6 is offline   Reply With Quote
Old 7-1-08, 12:33   #3 (permalink)
  Total: 10 Power: 4
I know I'm a little late but, thank you Seansjspecmx6!
