Old 5-23-08, 15:10   #1 (permalink)
  Total: 25 Power: 3
HID Halo conversion?
Can you put HID conversions on the H7 Ebay Halos?
JLCustomizing is offline   Reply With Quote
Old 5-23-08, 15:16   #2 (permalink)
  Total: 151 Power: 4
yes. but people will be VERY ticked off as the halo's dont have a cut off.
hers: 93 ZE. pretty much the same mods. + F&R drilled rotors, STS, h&r's
josey_gt is offline   Reply With Quote
Old 5-23-08, 20:15   #3 (permalink)
  Total: 25 Power: 3
12000k wont melt anything will it?
Old 5-23-08, 20:35   #4 (permalink)
  Total: 949 Power: 5
kid_puma's Avatar
HID Shouldnt melt your housing. In fact i would like to see pictures of that done. Imo, Angeleye halos illuminate very cool i dont know why everybody dislikes them.
DO-IT !
just make sure they are aimed correctly
Old 5-23-08, 22:02   #5 (permalink)
  Total: 327 Power: 5
ZE Power MX6's Avatar
The K-rating has nothing to do with operating temperature, so running 12000k is the same as running 4300k, and HID consume less power than halogen which mean less heat.
DO-IT !
The halo looks cool, but the cheap plastic housing is what other dislikes.
94 RS - The daily
Zoom-Zoom
Old 5-27-08, 7:54   #6 (permalink)
  Total: 384 Power: 5
I'd pay attention to josey_gt.
Evert is online now   Reply With Quote
Old 5-28-08, 21:46   #7 (permalink)
  Total: 13 Power: 1
omg ESPEC with a HID conversion and CCFL Halos....omg that would look sooooooo good
Killjoy101 is offline   Reply With Quote
Old 6-2-08, 21:30   #8 (permalink)
  Total: 16 Power: 1
CIPDAGR3AT's Avatar
Has anyone thought of chaging the LED light bulb for the halo.... or can you even change em out period..Is so let me know and
CIPDAGR3AT is offline   Reply With Quote
Old 6-4-08, 9:10   #9 (permalink)
  Total: 228 Power: 0
yes you can change the leds out. I have done it as well as many others on here. all you do is pull the old ones out slip them off get the right led and resistor solder them in place of the old ones and then pop them back in. it will take you maybe a hour. it looks better now that they match my car color but halos still suck it will be a good day when I can get my retros done!
Old 6-5-08, 19:06   #10 (permalink)
  Total: 191 Power: 5
shadow3030's Avatar
When I had the stock setup for my angel eyes I upgraded the leds. I replaced them with 360 degree viewing angle leds from Super Bright LEDs - LEDs I had to drill the hole out a little because I got the 8mm leds (9000k lumens) for more light. Looked ok but I wanted HID's so I retrofitted S13 projectors into the angel eyes and then got a hid setup.
Call me what you want, just dont call me late for dinner!
Originally Posted by scubasteve_07
They should have a drive through where you can get meatloaf around here...mmm...triple whopper
shadow3030 is offline   Reply With Quote
Old 6-8-08, 14:15   #11 (permalink)
  Total: 13 Power: 1
not tryin 2 start any controvesy, but can someone please make a rightup on how 2 take apart the Halo Housing and do the HID Conversion? or atleast take about the housing...the reason y i want this done is because they are plastic and idk how 2 get 2 it....i really wanna do the HID conversion on the halos cause i really dont wanna pay 350 on some especs....please let me know
94 MX6 LS---Bone Stock for now performance wise.
Old 7-1-08, 20:21   #12 (permalink)
  Total: 25 Power: 3
It was easy to install the halos, i took a flat head screw driver and popped off the rubber piece behind the headlight, took the headilght out and switched it. Then i cut off the piece that plugs into the headilght bulb and splice the appropriate wires together and wala, lights that blind everyone. I only get the finger about once a month. I have 12000k's in mine though and it already saved me from smaking a deer so it paid itself off in my eyes. I am switching back to stock headlights though, customizing them like Stealths write-up (excellent write up by the way) and using the TSX projectors, i feel bad for people that have to look into my headlights and the brackets on the halos just blow.
