Old 2-16-09, 10:36   #91 (permalink)
  Total: 850 Power: 5
ragincanadian4's Avatar
The front will, but you need the calipers too man, you can't get just the rotors.
J to the D to the M.
Old 2-16-09, 12:28   #92 (permalink)
  Total: 240 Power: 3
yes, but ONLY if you have the corresponding year's calipers. they won't fit the stock calipers
Originally Posted by willfinch36 View Post
Old 3-30-09, 9:46   #93 (permalink)
  Total: 285 Power: 4
And the brackets as well. The brackets set the caliper at a certain distance from the hub and determine how big a rotor you can fit.
Besides the mazda6 calipers wont fit the mx6 bracket.
Old 4-13-09, 7:21   #94 (permalink)
Car of the Month - May 09
  Total: 30 Power: 4
Hi guys, I cant see any of the pics in the opening thread, on IE or firefox.
I need a pic of the bracket that is needed to go with the caliper URGENT as i've found a cheap pair and want to get this done.
Can someone please post a pic of what I need or PM me. Thanks
[color="Yellow"]I've taken people's money, without delivering goods. I've lied about it, too! DON'T DO BUSINESS WITH ME!
Old 4-13-09, 8:54   #95 (permalink)
  Total: 850 Power: 5
You just need the bracket that corresponds with the caliper, it looks a lot like the stock bracket but bigger.
Old 4-14-09, 12:00   #96 (permalink)
  Total: 30 Power: 4
Got a question, I have 17" rims and stock calipers. I can get hold of a pair of 2003 Mazda 6 calipers from a 2.0 Diesel (150ps) for $75.
Question is, will these only take the 11.1" rotors or can I go bigger?
I can get all 4 calipers for $100 but i'm not clued up on wether the rears fit ok and the e-brake will work.
I've tried reading thru the thread but its frying my brain a bit.
Any help is appreciated.
Old 4-14-09, 15:28   #97 (permalink)
  Total: 14 Power: 5
I,ve tryd them on my 6 windy but the calipers and brackets on the european 6 are different then the american
willemmx6 is offline   Reply With Quote
Old 5-14-09, 23:56   #98 (permalink)
  Total: 570 Power: 5
Chefsp0t's Avatar
It's a good time to bump this. I am going to a huge you-pull-it yard tomorrow with my brother and I am going to see if I can find a set of front brake calipers off a new mazda. I'll let you guys know what I find (if anything).
2004-2009 Mazda3's with a 2.3 liter motor all used an 11.8" front rotor so I might give them a shot. I fit my 16" wheels onto my 09 mazda3 hatch so they should clear the wheels when they're on my mx6.
2006-2008 Mazda5's with a 2.3 liter also use an 11.8" front rotor.
My vBGarage
2009 Mazda3 Hatch Sport 5 speed: Daily driver
Old 5-17-09, 4:01   #99 (permalink)
  Total: 88 Power: 3
I have the 2003 Mazda6 set up on mine right now.The 11.1" rotors and all, and although I did not actually try them with the stockers, 15's, I am very sure they would not fit.
Bah, I've got 17's, and I really want the MS ones now, to really fill my wheels up... Ugh, haha.
A Simple MX6 is offline   Reply With Quote
Old 5-17-09, 15:16   #100 (permalink)
  Total: 570 Power: 5
Chefsp0t's Avatar
My 16 inch wheels fit onto my mazda3 which has the 11.8 inch rotors. They should clear just fine on my mx6 too.
My vBGarage
Old 6-12-09, 1:59   #101 (permalink)
  Total: 17 Power: 4
Talking Mach 1
I been working on my big brake set , for some time now..... I decided to go with the mach 1 ...had this set up for over a year ...so here we go ...!! stay tuned ...( rotor is BIG...2 piston .caliper ...)
24klze v6!
24klzev6 is offline   Reply With Quote
Old 6-12-09, 13:15   #102 (permalink)
  Total: 88 Power: 3
I hate to question the relevance of this to this particular thread, buuuut....
But I ran across a 2003 Mazda6 in the jy not too long ago, and I'm running those brakes now.
I know this may be a stupid question, but what happens if you run this all without the little clip things inside the calipers? The little thing that comes out with the pads, almost looks u-shaped, and goes to both pads. I'd take a picture, but it'd be more of a what isn't here picture..
Old 6-12-09, 13:48   #103 (permalink)
Josh Bannings = 1
  Total: 489 Power: 4
Nealio's Avatar
Those are silencers from what I can tell.
Eaton? - AWR - Mazdaspeed Acc. - Injen - CP-E - Greddy - ProSport - Corksport - Falken - Voodoo - MTX - Medieval Motorsports - Heronew - Apexcone - OBX
Old 6-12-09, 20:30   #104 (permalink)
  Total: 17 Power: 4
Talking Mach 1 set up....
did it ! here's the outcome ....
waiting on ss line to test ...
this is from a 2004 mach 1 .. with 2 piston caliper ...rotor size ..(big) wheel size ..17.R..
rotor difference..
and
stock size = 10 1/8
mach 1 = 13" WOOOOOOOOOOOOOOOOWWWWWWWW
wish me luck ..,,,,!!!!this could be a good set up for all....
cheers!!,"never fear the unknown"
ps!!! dont be a hater !!!
Last edited by ragincanadian4 : 6-13-09 at 3:18. Reason: Can I get some friggin carriage returns?
24klze v6!
Old 6-13-09, 2:03   #105 (permalink)
  Total: 88 Power: 3
How does it bolt up though? Bolt on, no modification?
