Old 10-21-09, 9:41   #121 (permalink)
  Total: 570 Power: 5
Chefsp0t's Avatar
Want to make copies of the bracket? I might be interested.
My vBGarage
2009 Mazda3 Hatch Sport 5 speed: Daily driver
Old 10-21-09, 19:33   #122 (permalink)
  Total: 387 Power: 5
ZE Power MX6's Avatar
I actually thought about that, but first I need to confirm all the parts first, hint: order those hats and rotors and make sure the whole kit fit properly, then I can decide if I want to make copies of them or not, it also depend on how many people are interested.
94 RS - The daily
Zoom-Zoom
Old 10-23-09, 15:35   #123 (permalink)
  Total: 570 Power: 5
Chefsp0t's Avatar
The ms3 front calipers won't fit the mx6 without a bracket being made. The space between their mounting holes is smaller than the mx6's. Making brackets probably wouldn't be too difficult though.
My vBGarage
Old 10-24-09, 13:13   #124 (permalink)
Josh Bannings = 1
  Total: 489 Power: 4
Nealio's Avatar
But if you are going to need a bracket, you might as well start with a better caliper.
Eaton? - AWR - Mazdaspeed Acc. - Injen - CP-E - Greddy - ProSport - Corksport - Falken - Voodoo - MTX - Medieval Motorsports - Heronew - Apexcone - OBX
Old 10-24-09, 16:14   #125 (permalink)
  Total: 387 Power: 5
Yea, if you need to make a bracket, I would go with at least a 4 piston caliper.
94 RS - The daily
Zoom-Zoom
Old 10-24-09, 18:55   #126 (permalink)
  Total: 570 Power: 5
Chefsp0t's Avatar
We'll see. The caliper is definitely an upgrade anyway. The pads are much bigger than the mx6 and the rotors are huge.
My vBGarage
Old 10-26-09, 15:21   #127 (permalink)
  Total: 88 Power: 3
Originally Posted by bmxfuel007 View Post
keep in mind, the 03-05 calipers should fit fine
however since the 06-07 and up calipers are bigger, even with the latch being the same size, because the caliper is bigger, the latch location is pushed back a bit so that if you are able to get the cable on, it may be partially pulled.
the mazdaspeed calipers are even bigger....
this is what I think. Haven't purchased larger rear calipers yet, but I'm still holding out for 98+ 626 v6 calipers, which are the same size as the 03-05 calipers. I have 06-07 front calipers, enough stopping power for now. brake upgrades are expensive
Wait, so the 03-05 Mazda6 calipers should have the stock parking brake cable reach them just fine? Iirc, mine didn't seem to be long enough, but that was back in April.
Does anyone know if they do fit for sure?
1994 MX-6 LS Hunter Green/Black - Outlaw Thermo Spacers, King6 Motor Mounts, Weapon-R Intake, Tokico Struts/Springs, Mazda6 Brake Conversion Front+Rear, 17" MSR's, E-Specs, Corbeau Racing Seats, Black Interior Conversion + Full Pioneer Audio
1988 RX-7 GTU Rusted Orange - Turbo Rear End, Coilovers w/ Tein Drift Springs, Slotted/Drilled Front Rotors, Black Aluminum Hood, S5 Tails
A Simple MX6 is offline   Reply With Quote
Old 10-26-09, 20:00   #128 (permalink)
  Total: 285 Power: 4
Nice work fitting the Mach/terminator calipers and rotors, I always thought the SN mustang brakes would nearly fit but the only ones I found localy were the base 2 pot calipers and smaller rotor set that came on the revised SN's.
Disapointing to hear about the 3 brakes not fitting, It's proabably just the bracket though. The rotors and calipers look identical to the Mazda 6 counterparts.
Still working with the FD 4 pots
Old 11-19-09, 0:35   #129 (permalink)
  Total: 88 Power: 3
I think someone should make brackets that allow the parking brake cable to bolt up when you use Mazda6/Speed6 brakes on the Mx6. I would if I had the tools...
