Originally Posted by mushkid
iirc, the k8 cams didn't give you that much of a gain. It's not worth the hassle, nowadays you can source ze cams for cheap, or have colt cam re-grind your de cams
He already has k8 cams, it's a mx3 and he want's different ones.
Basically if you swap out the cams i wouldn't do it unless they are kl31 cams. I don't think you'd see much difference in power but rather a difference in power band if you go with kl01 cams. The k8 manifold like the ZE's is better for top end power which is what the kl31(ze) cams with give you.
