Msns-e full pnp nlt starting up car. - Mazda MX6 Forums: MX6 Forum
Old 4-25-11, 8:03   #1 (permalink)
  Total: 221 Power: 5
mazdaspeedX6's Avatar
Hi all i posted this in the standalone section but seems like no one hardly looks in there. So here it goes i have a 93 mx6 ls 3 or 4 years ago i had fastest91pgt aka as jeff build me a unit msns-e very good guy and good at explaining things too. Now this was 3 to 4 years ago i had my ze car ran with ms but being a noob at the time i wasnt aware the motor was going bad yea dead cylinder at #1. We even tunned it at with a bad cylinder 135hp 131tq yea bad ze. Sooo i had a kl302 built and put in car didnt start i had stock ecu in car wouldent fire up so i did hei mod with blaster2 coil car starts and runs now went putting ms back out not start just cranks and cranks i notice when the clutch is pressed it say lauch on in red only when pressing the clutch. Its msns-e full pnp using megatune 2.25b file is as
026a when but when pulling what time
Of unit it is from other versions on megatune it says msns-e 025z. My question in all this is do i have to mod the ms board to work with hei setup amd blaster2 or would it be a simple update of the firmware and changes in the ignition settings. I have in mind selling this unit and getting a more updated one but before i do might as well find out if and still i can use this unit. Help please.
93 mazda mx6 Ls ford sb 302 rods.custom klze diamond pistons 10:1, klde head ported and polished 1mm over size than klze 5 angle valve job interprep tuning valve springs with klde retainers toga hp valve seals.klze intake manifold with 67-70mm throttle body outlaw thermol block spacers. De cams- broke ze intake need new ze or performance cams. Short ram intake ssa headers 2.5 front to back. Cross drilled slotted rotors. Megan R rear strut bar.
mazdaspeedX6 is offline   Reply With Quote
