so I had attempt one for the g4 ecu install without success, if I have time I'll try it again tomorrow, even though it, at this time, won't be permanent, if I can get it to start I'll be happy...my car is a 94, and the harness I hacked up is a 93, I've ran into 1 important wire that isn't in the same spot between the 2, I'll actually look at it all tomorrow and see if there are more, and correct as needed, but all my splices are good per the voltmeter, I still have a couple things I need to work out before a permanent install of the ecu, such as fans and a/c...I have 3/4 of hte fans worked out, and am thinking it to be easier to run an aftermarket fan setup to eliminate the 2 stage fans, needing 4 ecu outputs for them...well, I guess 3, but the a/c is completely different between the 2 ecu's...
also, the wheels pictured above killed power, but for a hard rubber tire (720 treadwear, I think) they stick surprisingly good
and are awesome in snow. Rubber is yokohama ascend 225/45/17, if I can get 2 years out of them, that would be great, though
