front/rear sway bar options? - Mazda MX6 Forums: MX6 Forum
Old 11-10-12, 17:20   #1 (permalink)
  Total: 10 Power: 1
after some searching it looks like i can get a decent aftermarket rear sway bar for like a buck 60...but what about the front?
i am going to be replacing all my suspension bushings soon and would like to go ahead and beef up both sway bars while i'm down there.
are there any sway bars that are interchangeable from one of our cousins?
inquiring minds want to know. any information you could provide would be awesome.
93 MX6 I4 MTX
bone stock...but not for long.
ohnoitsthatguy is offline   Reply With Quote
Old 11-10-12, 17:54   #2 (permalink)
  Total: 1734 Power: 5
KING6's Avatar
not only is the front a pain to do remove.. its plenty big for these cars.. unless its rusted and broken... I would leave it.
I am int he process of offering poly bushings for the front.. other then that there is no options.
Old 11-10-12, 23:03   #3 (permalink)
  Total: 10 Power: 1
right on...so '01 626 rear sway bar for the win? with 99 altima bushings?
93 MX6 I4 MTX
Old 11-10-12, 23:08   #4 (permalink)
  Total: 27 Power: 3
friendsofdonr's Avatar
get 95 altima endlinks.... also the contour, mystique and cougar fit our as well, the svt or v6 options have a 21mm rear sway bar..... no options for the front. @king, whats the price point on the bushings?
http://www.mx6.com/forums/garage/1005
http://www.mx6.com/forums/2g-mx6-oth...ld-thread.html
friendsofdonr is offline   Reply With Quote
Old 11-10-12, 23:24   #5 (permalink)
  Total: 10 Power: 1
just checked out king's website.
looks beefy...how much of that stuff is compatible with my 93 FS?
93 MX6 I4 MTX
Old 11-10-12, 23:39   #6 (permalink)
  Total: 27 Power: 3
I'm running a contour rear bar with all-time end links on my fs right now. The ls and rs or base model are identical on suspension except the bigger rims and disc brakes.
Old 11-11-12, 0:42   #7 (permalink)
  Total: 10 Power: 1
the more i learn about this car...the more i like it.
93 MX6 I4 MTX
Old 11-11-12, 11:46   #8 (permalink)
KING6's Avatar
Im working on a larger sway bar for the rear aswell.. its a bit more difficult. But right now im the only one offering heavy duty parts for the rear sway.
Old 11-11-12, 12:03   #9 (permalink)
  Total: 18 Power: 5
^ are you going to make the reversed style rsb again?
97mx6 is offline   Reply With Quote
Old 3-7-13, 6:40   #10 (permalink)
  Total: 10 Power: 1
what year contour? and whats the largest diameter out there?
93 MX6 I4 MTX
Old 3-7-13, 9:36   #11 (permalink)
  Total: 27 Power: 3
thats supposed to say "altima" endlinks not alltime.... any year contour.
Originally Posted by MazdaMan88 View Post
This is what I dug up. You can use the rear sway bars on the 95-00 Contour/Mystique,
The year, trim levels, and sizes:
1995-1998 GL&LX -17mm
1995-1998 SE - 19mm
1998.5+ LX I4 - 16mm
1998.5+ LXV6 -17mm
1998.5+ SE All - 18mm
All SVT V6 - 18mm
As for endlinks, you can use the factory MX6 endlinks (the Contour ones are too long), but the fitment is awkward because the bar is a bit longer than the OEM one. Either 2nd gen RX-7 rear endlinks or an adjustable set that allow a bolt to pass all the way through will work perfectly.
the downside is they are about 2-4" longer so your endlinks have a bit of an angle on them. and there is a hump in the bar that made me wonder if it was bent. simply a cosmetic thing. mine fits pretty well though. handling is amazing.
Old 3-7-13, 9:37   #12 (permalink)
  Total: 27 Power: 3
and i'm running 1995 altima endlinks.... for the record.
Old 3-7-13, 19:09   #13 (permalink)
  Total: 480 Power: 5
01 626 rear bar FTW. Its the same size as the Contour bar, and fits even better then the contour bar. Plus i just re-used my stock endlinks. Total cost of upgrade was $6 bux at a junkyard.
