high idle - Mazda MX-6 Forum
post #1 of 3 (permalink) Old 1-22-13, 23:20 Thread Starter
Power: 0
high idle
hey my mx-6 is idle high does the the throttle position sensor control idle or the idle control valve could be sticking i found the tps where is the idle control valve? v-6 96 any help thanks
david chapman is offline
post #2 of 3 (permalink) Old 1-23-13, 5:33
PaulG's Avatar
Quoted: 26 Post(s)
Power: 6
The iac is attached to the bottom of the throttle body. Due south of the tps.
1997 MX-6 LS
PaulG is offline
post #3 of 3 (permalink) Old 1-25-13, 14:04
djdevon3's Avatar
Quoted: 2 Post(s)
Garage
The throttle position sensor reports throttle angle (butteryfly valve) to the ECU. It does not control idle speed however if it is incorrectly calibrated/positioned it could cause a high idle yes. Do a search on the diagnostic procedures to ensure that it is reporting the correct position while at idle. If it is incorrectly positioned during idle it most likely means it was set incorrectly in the past by someone. 99.9% of the time there is no reason to ever remove or reposition the throttle position sensor.
djdevon3 is offline
