Old 6-6-02, 12:12   #16 (permalink)
hmm I will also have my turboed I4 dynoed on the 22nd at the FLAPOC dyno day. As far as producing over 200hp, I'm estimating around 300 when my pistons and rods arrive in august. I will put money that I will be boosting over 250hp.. Oh yeah this would be at the wheels folks.....
"You hate people" ..."Yes but I love get togethers...Ironic isn't it?"
MX6Guru is offline   Reply With Quote
Old 6-6-02, 20:59   #17 (permalink)
well that sux, i should just got back to owning a rx7
well its been a long long time......but it still moves one mile at a time lol
italnlvr20 is offline   Reply With Quote
Old 6-21-02, 10:30   #18 (permalink)
Why can't MX6 beat an RX7 ?? *cough... I did it everyday
( with a poorly maintain non-turbo automatic FC )
Does you father has a FC(88-92) or FD(93-97) RX-7 ? Turbo or non-turbo ?
A non-turbo FC is 160hp@7000 rpm , with 2800lbs weight.
Make sure you has at least 170hp in your 4cylinder. You should be able to line up with your dad in quater mile, with good shifting skill
OR take the advantage of piston-powered engine.
Told your dad, both of you start off at 2nd gear for 0-60... hehehe... I am sure you will win.
oh.. I love and hate rotary engine.
93 MX6 LS 4cycl 2.0L Mtx
Nitrous - been there, done that. Air is free, go turbo !
~ May the boost be with you ~
rosecuvee is offline   Reply With Quote
Old 6-22-02, 0:49   #19 (permalink)
I beleive so... when are we going to go head to head to end the supercharger vs. turbocharger debate? LOL
93 2.0 Brospeed Header, test pipe, Brospeed Cat Back exhaust, R.S. Akimoto Cold Air, Ground Control Coil-overs, Strut tower bars front and rear. Thomas Knight EAton Supercharger Kit( 12lbs of boost), Walbro 190 fuel pump, Pauter custom rods, JE pistons, 3 angle valve job, block bored 40 over, Clutchmasters Stage 4 clutch, Spearco Water/Alcohol Injection.
Check out mysite: www.geocities.com/noocluee
14.3 @ 96mph
BLOWN MOTOR!!!! REBUILD IN THE WORKS!
noocluee is offline   Reply With Quote
Old 6-22-02, 3:08   #20 (permalink)
apexi s-afc
can anyone help me with wiring a apexi s-afc to a 93 mx6 4 cyl any help would be great
slimm609 is offline   Reply With Quote
Old 6-23-02, 16:35   #21 (permalink)
I'm doing a complete engine rebuild and found a place that can pretty much give me a new block and what they do is bore it out and resurface the block for less than $300 and I've been told to bore out the block to .40 for the best results so would the J-spec pistons set fit, are they .40 in size?
'93 2.0 Shogun/Buddy Club MX-6 w/ 17" rims:Custom K&N CAI,prd sts,Technology Hi-Flow cat-converter,custom 2 1/2'' cat-back w/ mandrel bend,Ractive muffler w/ 4 1/2' tip,INTERIOR: R-1 racing tach w/ shift light,Diamond Plate floor mats,MOMO shift boot & knob
ssaiyan4m is offline   Reply With Quote
Old 6-23-02, 20:23   #22 (permalink)
No the jspec pistons will not fit. The jspec pistons are stock bore. You are going to have to have a set made in .40 over. Call Je Pistons They should still have a mold from where they made mine.
14.3 @ 96mph
Old 6-24-02, 1:29   #23 (permalink)
what's the # to JE Pistons and how much did they charge you for your set?
Old 6-24-02, 12:55   #24 (permalink)
Call Phil at Flatlander Racing the number is (603) 378-0090. This guy know his stuff and will be glad to help you. You dont want to deal with JE Directly their customer service and sales help is the worst in the world. (Bunch of rude A**Holes). As far as price I think mine were like $690 for pistons and Rings. I had the compression ratio lowered on mine too though so that may have cost me a little more. Hope this helps you. Definitly call PHil At Flatlander.
14.3 @ 96mph
Old 7-11-02, 8:46   #25 (permalink)
Originally posted by parisifal
And just as the KL-03 has a powerful twin in the KL-ZE, so does our FS-02. In 1997, Mazda Motor Corporation, on the verge of bankruptcy decided to create a new series of I4 engines. They adapted the VRIS into the I4 through a system called the VCIS. Thus the FS-ZE was born, making well over 170hp in the raw stage and ending up with 170hp after emission standards toned them down.
VICS, not VCIS.
The FSZE sports VICS, higher compression, different intake cam, distributor-less ignition, d-burn, and a different engine management program (in OBD-I though) to produce:
168 hp @ 6800RPM
131 lbs/ft @ 5000RPM
With the D-Burn EGR system, it should pass domestic emissions.
The Intake manifold is also not worth buying since you have no way to control the VCIS so it is useless. You are better off Portign and Polishing your stock IM.
The intake manifold would be a great modification for people not going FI and not going for the entire FSZE installation.
With the VICS system installed, you would retain more of your lowend power while increasing your topend. P&P it would net nice results and would be best to do before installation.
You can't control the VICS system with your stock ECU, but you can use an RPM dependent switch from MSD and the stock opening/closing charts from a P5 FSDE.
You could hop on a dyno and come up with more accurate numbers to match your car and performance goals, but the P5 numbers should suite most modders quite well.
It's a costly modification, though; but when compared to the cost of a header, exhaust system, etc ... it's not that bad.
BTW, your steps are very odd ... but I'll leave my specific comments concerning that to myself.
94SE is offline   Reply With Quote
Old 7-20-02, 10:10   #26 (permalink)
  Total: 282 Power: 5
taken from a PTer credit to him or herRear brake Drum to Disc conversion
M(y)x6gr8RiDe is offline   Reply With Quote
Old 7-21-02, 15:53   #27 (permalink)
what would be the ideal piping for an exhaust for our I4's from the cat converter and what is the best free flowing cat converter and where can I buy it online?
Old 8-23-02, 23:41   #28 (permalink)
Brammer
can the fsze efficently handle a turbo/supercharger or nos very well? or should i just go with my i4 engine?
i dunno much about mazda mx6 cars that much just got my mx6 a week and any help would be great to make it fast as it can and look nice for a non Ls mx6.
thanks Brammer
Old 8-24-02, 19:36   #29 (permalink)
Don't supercharge or turbo the FSZE b/c its a high compression engine (I think 10:1 ratio) and would practically blow up. You could safely put NOS on it but, only go w/ a small amount like a 50 shot of NOS.
One thing there is only 1 person I know of that successfully put on the FSZE and the engine is mounted on a Ford Probe! The biggest problem w/ the engine is the wire harness!
Old 8-25-02, 18:11   #30 (permalink)
Brammer
what would the recommended way to go for a i4, just turbo it?
thanks brammer
