need to prove friend wrong - Mazda MX6 Forums: MX6 Forum
Old 7-22-03, 3:44   #1 (permalink)
im sure this has been gone over before, but i have no patients when it comes to looking for things. me and a freind were discussing mazda engines today, and he said that the millenia has the exact same engine as the mx6, i said he is wrong. what engine does the millenia have, and what are the differences
MrMazdaMan is offline   Reply With Quote
Old 7-22-03, 4:15   #2 (permalink)
  Total: 23 Power: 5
the milenia came with 2 engine options one being a 2.5l v6 same as the one in the mx6 and 626 and the other was supercharged 2.3l v6 guess your friend was right
sik6 is offline   Reply With Quote
Old 7-22-03, 4:51   #3 (permalink)
damn, so they did come with the kl03. huh, then why did they only come atx, does anyone know if anyone did a mtx swap?? i wouldnt mind to have one and do the swap
Old 7-22-03, 15:19   #4 (permalink)
  Total: 184 Power: 5
nope, the kl in the millenia is a little different. The IM is a little bigger, the sensors are located a little differently. I believe that the cams are also a little more aggressive, forgive me if I'm wrong.
If they're the same engine, then why are so many people swapping with millenia parts??? They are a little different.
^The above post was typed by me...in the nude^ (_|_)
Thanks Mark!
DHC Baybee! - Dye or Die Fother Mucker!!
Wyldeone22 is offline   Reply With Quote
Old 7-22-03, 15:22   #5 (permalink)
  Total: 250 Power: 5
From what I hear, it's a mix of 03 and ze parts....
Not sure on that though.
-Chris
easyBob is offline   Reply With Quote
Old 7-22-03, 19:10   #6 (permalink)
  Total: 71 Power: 5
maybe you were both right.
1997 VW Jetta GL Windsor blue, 17" Slvr/Gnmtl Motegis, new rubber, 5% all around, full pacesetter 2.25" system, ebay intake, strut tower bar, hyperwhites, clear bumper lights, eibach's, gr-2 struts, aluminum dash kit/shift knob, carbon fiber gauges, JVC motorized screen/6-disc, talking alarm, you name it....
*voted sweetest ride class of 05* ....even after I sold it
CustomMX6 is offline   Reply With Quote
Old 7-22-03, 20:23   #7 (permalink)
The Full Dong
  Total: 450 Power: 5
Radar's Avatar
The Millenia does indeed come with two engines...one is a supercharged miller cycle engine and the other is a a bit different then the one found in the 626/probe/mx6. The heads are the same (KL31) as the ZE heads...they flow better and have the squared off ports. The IM is also different...it flows better than ours.
Turbo KL 400whp/407tq - SHAODOME @ PROBETALK
Successfully Megasquirted: 94 MX6-ZEt, 92 MX3 ZE, 94 MX6 LS, 96 PGT ZE, 96 PGT w/ every bolton, 93 PGT, 93 PGTZE, 95 PGT ZE, Celica GTS built 20v-turbo, 95 PGT, 97 PGT ZE, 97 MX6 KLZE, 97 PGT w/ botlons, Mazguy's Built MX-6 Turbo, 97 Mustang V6 EDIS, Delorean with a T70 Turbo, and a 87' Built 1.8t VW Golf (25psi),97 SE-T. No more sig space
Radar is offline   Reply With Quote
Old 7-22-03, 22:25   #8 (permalink)
thank u guys, i almost knew that they were the same but with different parts, but this proves me right because when he said they had the Kl03, he was pointing at the millenia S
