Old 6-25-04, 21:54   #1 (permalink)
  Total: 32 Power: 5
barkster's Avatar
Question Headers
I know this topic is old... but, so are most of the posts.
I need to replace the stock headers in my 93 LS... they are rusting. And after all I've read on this subject here and on PT (and all the new product developments... gen III, gen IV, etc...), I'd welcome some fresh recommendations.
I understand the physics and all the talk about scavenging, pressure waves, flow, and so-called "backpressure"... good, bad, or otherwise. Do I want to lose torque? No... but I'm not looking to gain any for the moment, either. What I'm after for now is mid-to-top RPM performance boost.
I've seen the web pages for Borla, Bosal, Hotshot, Pacesetter, and others.... I'd like to hear more about your knowledge and experience with any specific brands on the following points:
base materials (mild vs. stainless)
coatings (ceramic vs. heat paints)
Fit and leaks (is it always hit-or-miss?)
flex pipe vs. ball joint vs. fixed (mid pipe)
welds and additional fittings required (if any, for a 93 LS)
2.25" vs. 2.5"
recommended additional thermal wraps
What, if anything, is really wrong with the OEM headers?
Thanks,
Glenn
Friends don't let friends drink cheap beer.
http://www.cardomain.com/id/the_barkster
AWR Struts, Sway Bar, Trailing Links, Rear Strut Bar, Engine Mounts
K&N Intake, SSAutochrome Headers, Random Tech Cat, Bosal Catback, Outlaw Spacers
Optima Battery, MSD Blaster 2, Bialy HEI Mod, NGK Iridium Plugs, Magnecor Plug Wires
CM Stage 1 Clutch, MX-3 Flywheel, Quaife Limited Slip Differential, SR KMC Racing Wheels, Toyo Tires
barkster is offline   Reply With Quote
Old 6-28-04, 14:34   #2 (permalink)
  Total: 90 Power: 5
Usually aftermarket headers will flow more...as the stock narrows at the flanges...I have thermal wrap on mine but Id say all that does really is keep the heat from destroying your distributor and starter
megamx6 is offline   Reply With Quote
Old 6-29-04, 0:42   #3 (permalink)
  Total: 953 Power: 5
There can be significant power gains in controlling the loss of energy in the exhaust. You want the exhaust to be as hot and high energy as possible, so that your careful tuning causes the very lowest pressure pulse possible near the exhaust valve when it opens. If you let the gasses cool down, they are less effective in this regard.
Practically, you are 100% right about what a good idea it is to keep the disty and starter cool.
Old 6-29-04, 3:50   #4 (permalink)
Eternal College Student
  Total: 522 Power: 5
Brad's Avatar
about the question - i have pacesetter and they work fine. dont know about the power increases though because i put them on along with every other mod i have at the same time. but the crafstmanship was decent and i dont have any leaks yet. it's been a little over 2 years
95 Mx-6 LS. Full 2.5 inch exhaust. Intake. ZE Manifold. FOR SALE!!
99 Acura TL. Stock, and staying that way.
My photography
http://lsu.facebook.com/album.php?ai...29&id=23425016
Brad is offline   Reply With Quote
Old 6-29-04, 10:42   #5 (permalink)
  Total: 953 Power: 5
I think that especially if you weld a flexpipe in, they aren't bad at all. Only reason I get so pissy about them is the bad experience I had with them on a couple different cars.
Up here, with all the deicer, I think they would be a good choice for a summer car.
-Garrett
Old 6-29-04, 12:45   #6 (permalink)
[fizzle] pacesetter!! those things leak like a sive(sp?)
i put the Bosal brand ceramic coated headers on my girlfriends car. (93 MX-6 KL)
before that i had installed the custom magnaflow exhaust, and K&N intake system, so other than sound and the top end power, there wasn't too much that impressed me.
You've gotta have a big c@ck to drive a car like this!
TheRacingVolvo is offline   Reply With Quote
Old 6-29-04, 14:10   #7 (permalink)
  Total: 28 Power: 5
the $600+ most quality headers for our cars cost im sure could be much better spent elsewhere, like some Bf Goodrich KD's
1996 Toyota Corolla 131k 5M
1996 Chrysler T&C 154k 4A 2nd tranny
1993 Ford Probe GL 123k 5M
1992 Toyota Corolla 161k 3A
1990 Plymouth Voyager 244k 4A 3rd tranny
JeremyL is offline   Reply With Quote
Old 6-29-04, 14:38   #8 (permalink)
  Total: 40 Power: 5
I've heard good things about HS, and plan to get them myself.
94 Mx6 5spd LS
94 Probe 5spd Base
My 6- http://www.krewhl.com/downloads/vic/mx6
Victheslic is offline   Reply With Quote
Old 6-29-04, 15:06   #9 (permalink)
yeah, they are kind of expensive, but i picked them up for about $460.00.(cost)
Old 6-30-04, 0:51   #10 (permalink)
  Total: 32 Power: 5
barkster's Avatar
Garrett, I believe you completely on that. I was looking at the RRE flex pipes, if the header didn't come with one.
Ok... I've heard much bad about pacesetters... if I can sheppard this thread back to the technicals, though...
Bosal = Mild steel with cermic coating. How does that compare to stainless and/or heat paint or powder coating? Maybe if I got Bosals and added a coat of heat paint before I installed them? Would that prevent the rapid rust formation that mild steel is susceptible to? Hotshot is mild steel (coating?) and I believe Pacesetters are stainless.
Oh yeh... and I'm moving to DC where it is HOT in the summer and more than cold enough for snow and corrosive road salts in the winter.
Thanks again, all.
Glenn
Old 6-30-04, 7:39   #11 (permalink)
  Total: 40 Power: 5
They use road salt here in Texas... On those 1/4 winters where it ices pretty bad.
94 Mx6 5spd LS
94 Probe 5spd Base
Old 6-30-04, 8:59   #12 (permalink)
  Total: 55 Power: 5
NHxj4x4's Avatar
That's funny, come northeast buddy, we turn cars to dust with the amount of salt they pour on the road, it's silly!
Jeep Guy getting in-touch with my GO-fast side..
93 MX6 LS. So far- Eibach pro's, Tokico Illumina's, 17" Exel H-50's, 215/45/17 meat. Strut bars, CAI, STS, OBX cat back, SPEC Stage II Clutch, MM Inserts, ASS LOAD OF AUDIO. Custom shift light. More on the way!http://www.cardomain.com/memberpage/575155/5
NHxj4x4 is offline   Reply With Quote
Old 6-30-04, 9:02   #13 (permalink)
  Total: 953 Power: 5
Hehe yeah, up here they don't just dump NaCl on, they use KCl on real cold days, which is even more corrosive.
And, since its a byproduct of the industry and super cheap, they are now using MgCl, which will eat through rubber balljoint boots in months and all sorts of nasty things.
-Garrett
Old 7-1-04, 12:51   #14 (permalink)
yeah, that potasium **** is definitly corosive.
i think that you should get a set of bosal headers. you could always shoot them with a high temp paint if needed, but the ceramic holds up pretty well. how long do you plan to live in that environment? i think that there wouldn't be any harm in painting them as long as you used a high temp paint and maybe few coats. thinking about this more i woul probably go ahead and do this so that you can try to prevent raock chips from starting the steel wrought procces.
no harm in that, right.
Old 7-1-04, 14:09   #15 (permalink)
  Total: 32 Power: 5
barkster's Avatar
I guess not.... and thanks for the reply... (I grew up in Marietta, by the way.... tell me the "big chicken" at 41 and Roswell is still there, please!)
So... if the ceramic and an extra layer of high temp paint are enough to counter the downfall of mild steel... then maybe it looks like Bosal or Hotshots are the choice for me. I here a lot that Hotshots fit very well, but don't offer too much in boost. How about the Bosals? Any fit/leak problems with those (like I always hear about Pacesetters?).
Putting it all together, now... does anyone have any mechanical or material warnings, experience or advice AGAINST the following: (and sound doesn't matter)
Bosal headers, an aftermarket (RRE?) flex pipe (I don't thing the Bosal comes with one), Random Tech high-flow cat, and "yet to be determined" catback.
Is flanged or welded better?
Answer that and I think I'll be ready to go shopping.
Glenn
