Go Back   Mazda MX6 Forums: MX6 Forum > 2G MX6 (93-97) > 2G MX6 General > 2G MX6 Projects/FAQ
Old 7-26-02, 5:21   #1 (permalink)
  Total: 12 Power: 5
Red Tail Lights
The paint is called Testor's Transparent Candy Apple Red, it comes in a 85g spray can (fairly small) and the number on the top of the can is 1605.
How I did this:
1) Clean the taillights with rubbing alcohol or whatever.
2) Tape the area around the turn signal... be careful, this takes awhile and alot of tape to get the curves right. There is a slight groove around the turn signal, so you can follow that. Also tape a garbage bag to this edging to protect your car's paint job.
3) Spray a thin coat onto the turn signal, spraying over the edges onto the garbage bag. The paint says 2 hours or something between coats, but I did 20-30 minutes or so, you can tell when it dries because it becomes whitish (sort of).
4) Spray two more even coats onto this area after the previous one dries.
5) When the final coat has dried, use 3-4 coats of clearcoat (I used 4), to give the shiny look.
6) Remove the garbage bags and tape after the clearcoat has dried.
There really is no comparison in my opinion, this is a cheap mod and I think it looks 100% better than the stock tails. From a distance, you can't tell the lights have been painted, although close-up it is evident since the layers of paint and clearcoat protrude slightly from the surface of the taillight. And yes, the turn signal flashes RED, not ORANGE!
-straight from HotNikks
datboidavid is offline   Reply With Quote
Old 4-1-08, 17:28   #2 (permalink)
  Total: 5000 Power: 6
Goatcrapp's Avatar
whitenoyz would like to share his method - added below in the quote.
Originally Posted by whitenoyz
A much easier way is to tape down newspaper and make the scotch tape straddle the line, then use an xacto knife to cut right on the outside of the line, then peel off the tape on the inside. for most people, this will make the line a lot sharper and crisper, and will take much less time than putting tape around all the curves, especially with the sharp curves on the outside. I tried posting a reply but it said I couldn't, something about user access privileges i think.
HTML code is On
