Go Back   Mazda MX6 Forums: MX6 Forum > 2G MX6 (93-97) > 2G MX6 General > 2G MX6 Projects/FAQ
Old 5-2-04, 0:05   #1 (permalink)
  Total: 331 Power: 5
neptune_51's Avatar
How To: Paint Your Rims (Stock or Not)
hey all,
i felt like painting my rims and since i had my friend's digital camera, i decided to photo document the whole job.this will hopefully guide you through it....
Materials Needed:
600 grit sandpaper
2000 grit sandpaper
primer
paint colour of your choice
clearcoat
jack
white gas
lots of rags
tape and newspaper
http://i192.photobucket.com/albums/z85/neptune_51/My%20Stuff/5eba.jpg
here's a close up on the paint if your wondering what type i used,
http://i192.photobucket.com/albums/z...Stuff/d3e9.jpg
2006 Honda CBR600rr - daily driver/rider and potential death machine
Originally Posted by neptune_51
Who would be stupid enough to quote themselves in a sig?
Old 5-2-04, 0:07   #2 (permalink)
  Total: 331 Power: 5
neptune_51's Avatar
first off, you will want to jack the car up
http://i192.photobucket.com/albums/z85/neptune_51/My%20Stuff/6098.jpg
then remove the wheel...
http://i192.photobucket.com/albums/z...Stuff/8bd6.jpg
then your left with this beautiful sight
Old 5-2-04, 0:10   #3 (permalink)
  Total: 331 Power: 5
neptune_51's Avatar
after the rim is off, take a good look at it. if there's lots of dirt like mine, then you definetly need to clean it (duh!!)
http://i192.photobucket.com/albums/z85/neptune_51/My%20Stuff/a0a7.jpg
as you can see mine are pretty bad
next you need to clean out the entire thing. use a cloth and the hose to get most of the visible dirt
http://i192.photobucket.com/albums/z...Stuff/4635.jpg
after cleaning the rim, start sanding with the 600 grit. go through the entire thing so that it's super smooth
http://i192.photobucket.com/albums/z...Stuff/8352.jpg
you can sorta see the places where i sanded in the picture...
Old 5-2-04, 0:15   #4 (permalink)
  Total: 331 Power: 5
neptune_51's Avatar
after sanding, use the white gas to clean it again. just pour a little on a clean rag and wipe it into the rim. this SUPER cleans it. ( this step is optional, but since the rims are very visible, you want them to be super nice when your done. using the gas just helps clean it up that little extra bit)
anywho...
start masking the area around the tire with tape and paper. you can see from the picture that i got kinda creative. but its all up to you on how it gets done.
http://i192.photobucket.com/albums/z85/neptune_51/My%20Stuff/4eb5.jpg
just make sure you cover the tire. nothing worse than a colored tire
now you start the fun part.....
begin the priming.
http://i192.photobucket.com/albums/z...Stuff/9edc.jpg
http://i192.photobucket.com/albums/z...Stuff/dd62.jpg
i did about three coats.
Old 5-2-04, 0:18   #5 (permalink)
  Total: 331 Power: 5
neptune_51's Avatar
with the primer, i let it sit for about an hour between each coat.
and next is the painting stage
http://i192.photobucket.com/albums/z85/neptune_51/My%20Stuff/15c4.jpg
http://i192.photobucket.com/albums/z...Stuff/fca7.jpg
and this is the bolt cover
http://i192.photobucket.com/albums/z...Stuff/d71f.jpg
for this part, try about 3-4 coats with an hour to dry between each.
Old 5-2-04, 0:22   #6 (permalink)
  Total: 331 Power: 5
neptune_51's Avatar
now after letting the paint dry for about 2 hrs, begin on the clearcoat. go for about 3-4 coats, allowing for 10-15 mins to dry on each.
i let each rim sit for about a day before reinstalling on the car.
repeat these steps on the other 3 wheels and your set to go.
here are some finished pics
http://i192.photobucket.com/albums/z85/neptune_51/My%20Stuff/c85c.jpg
http://i192.photobucket.com/albums/z...Stuff/3716.jpg
http://i192.photobucket.com/albums/z...Stuff/20e0.jpg
http://i192.photobucket.com/albums/z...Stuff/4055.jpg
sorry i can't get any better finished shots... our garage door is busted and i can't get the car out.
hopefully my write-up has helped you.... and someone move this into the 2G projects area or somethin...
Old 10-10-07, 4:13   #7 (permalink)
Josh Bannings = 1
  Total: 489 Power: 4
Nealio's Avatar
Originally Posted by Picture Host
holy crap.
you broke the internet.
You (24.26.0.237) appear to have come from http://www.mx6.com/forums/2g-mx6-pro...stock-not.html (How To: Paint Your Rims (Stock or Not))
You attempted to access /pics/albums/userpics/normal_Dsc00312.jpg
404
four o fizzle
Fixable?
Eaton? - AWR - Mazdaspeed Acc. - Injen - CP-E - Greddy - ProSport - Corksport - Falken - Voodoo - MTX - Medieval Motorsports - Heronew - Apexcone - OBX
HTML code is On
