Go Back   Mazda MX6 Forums: MX6 Forum > Mazda Family > 626 General
Old 2-6-09, 5:22   #1 (permalink)
  Total: -5 Power: 0
How 2 turn a 626 in2 a time machine?
hey all, im planning on turning my 626 in2 a time machine and wondered if ne1 else was on the same path. atm im having trouble opening up a worm hole?
iwannaJspec is offline   Reply With Quote
Old 2-6-09, 7:06   #2 (permalink)
  Total: 327 Power: 5
mm2587's Avatar
what model flux capacitor are you using? What type of fuel are you using? have you checked the 02 sensors?
......|. .| Check out my fourm its like the lounge but better I have secrets too
\\\\\( V )///// They're scary
.\\\\/v.v\////
. \\\(vvv)///
mm2587 is offline   Reply With Quote
Old 2-6-09, 7:59   #3 (permalink)
  Total: 15 Power: 2
I'd say check your crew before you work on the car. If you don't have a lanky, awkward, crazy haired doctor with you, it will never run. Oh, that and gullwing doors
Lestat13 is offline   Reply With Quote
Old 2-6-09, 8:07   #4 (permalink)
  Total: 1721 Power: 5
Fastest95PGT's Avatar
In 4 lulz
PARTING A LOT OF 2g STUFF
FS: Craftsman 1/2" Drive Deepwall Impact Socket Sets
Old 2-6-09, 11:49   #5 (permalink)
  Total: 619 Power: 5
Gull Wing Door Kit:
Gull Wing Door Kit - Vertical Doors AutoLoc Gull Wing Vertical Door Kit
Old 2-6-09, 13:38   #6 (permalink)
  Total: 96 Power: 4
Eh, I've got a friend doing this with his Probe. On his second one, his first one managed to open a worm hole before it, but the car began to experience severe scorching, so it was aborted, the chassis was lost.
Make sure you're running a twin turbo setup. Each individual intercoolers, one routing the cooler air into the cabin, as otherwise you will suffer heat stroke. Second one needs to be considerably larger than a standard turbo, and N20 fed.
Of course, go through all the usual paces of weight reduction to what is only necessary, 5 speed over auto of course. Also, make sure all your fluids can handle extreme heat, recommended over 900 degrees Celsius, as the car gets really hot approaching time warp speeds.
We were running about 4.8:1 cr pistons by the way. Any higher with the boost we were running would've not only threw a rod, but the whole block it's self right out the exhaust.
Tell me if you need any more info to get started, I've got books of it up my bum.
Or maybe that's just my Government homework...
A Simple MX6 is offline   Reply With Quote
Old 2-6-09, 17:09   #7 (permalink)
  Total: -5 Power: 0
wow, i didnt think it would get so hot entering the time warp, how do the panels hold up in this kind of heat? i have already started replacing my hoses with stainless steel braided 1's. im not using p/s, and my brakes work by reversing the kenetic engery via magnetic nanotechnology reverse cycle system. Im using a stage 2 flux capacitor and im workin on a fuel system that can run on garbage.
Old 2-6-09, 17:17   #8 (permalink)
  Total: 87 Power: 3
Last night, Darth Vader came down from planet Vulcan and told me that if I didn't take Lorraine out that he'd melt my brain.
94 MX6 LS - DD, Mild Bolt ons. K&N, Borla,RR-Racing inserts, gutted cat amongst other things... I keep it clean though!
1964 k10 - Restore job. Mechanically rebuilt, now on to the body!
2006 Ford Fusion - Kid and Grocery Getter
Phoenician6 is offline   Reply With Quote
Old 2-6-09, 17:54   #9 (permalink)
  Total: -5 Power: 0
LOL i luv that movie! thats where i got my idea from
Old 2-6-09, 17:59   #10 (permalink)
  Total: 87 Power: 3
Haha welcome to the site dude
Old 2-6-09, 18:23   #11 (permalink)
  Total: -5 Power: 0
Ty i have sum crazy ideas(sum a lil ovaboared) but i want to create sum good disscusion of topics no 1 has ever tried like for example an awd mx6 with electric motors at the rear wheels. etc
Old 2-6-09, 18:41   #12 (permalink)
  Total: 585 Power: 5
Chefsp0t's Avatar
Actually both of those ideas have been talked about already. Just thought you should know.
Old 2-6-09, 18:57   #13 (permalink)
  Total: 327 Power: 5
mm2587's Avatar
Well that's part of your problem then, if you want to run on garbage your going to have to step up to at least the stage 3 flux capacitor. The stage two is just too power hungry its no wonder your not getting a stable wormhole, I mean come on its garbage not plutonium
.\\\\/v.v\////
. \\\(vvv)///
Old 2-6-09, 19:41   #14 (permalink)
  Total: 88 Power: 4
honestly, i think you should use a train, make it out of pinball machine parts. I did this and it worked pretty good.
1996 M-Edition-SS Sills, JDM Interior, Partial Black Interior Switchover.
JLCustomizing is online now   Reply With Quote
Old 2-6-09, 20:35   #15 (permalink)
  Total: -5 Power: 0
Yeah ur probably right the stage 3's arent cheap tho i might have to source sum plutonium, where did u travel 2 on your first run?
trains r to god dam expensive man!!!
