Old 6-1-05, 10:26   #16 (permalink)
The Mod With the Mostest.
  Total: 1076 Power: 5
Panther37's Avatar
I didn't know you guys had a different ECU.
Old 6-1-05, 10:31   #17 (permalink)
  Total: 200 Power: 5
unfrotunatly so otherwise we wouldnt need woo's mod we'd be using your zombie chip
1991 Tx5 Turbo AV 103KW on 12psi
Mods:
Hi Flo'd Turbo, 2.5" exhaust 4" Tip, 15" Pioneer Sub, 2xAmps, CAI, Woo's Mod, Boost Controller (14psi), Autometer Liquid Filled Boost Gauge, Pod Filter, Hi Flow Comet CAT, SUperlow Springs, Rear Strut Brace, WRX Front Bar, Front Strut Brace, FMIC...Soon To come: Zender Side Skirts
zorb_rules is offline   Reply With Quote
Old 6-1-05, 10:37   #18 (permalink)
  Total: 304 Power: 5
lol, i think i'd choose woo's still :P not that i have one atm, but i'd still get woo's since hes in melb, prob cheaper in the end, and i can get direct help from him etc with it
1990 GD mazda mx-6 turbo 4ws, Td05H turbo, custom manifold, 2500lbs rx7 clutch, 18" wheels with 225/35/18 rubber, Short Shifter, super lows, KYB struts, CAI, Exhaust, twin pot Liberty GT calipers, walbro 255lph fuel pump, 18mm rear swaybar
Traded With: Crazyone, Adamx6, Mitchyboy, TX5F2T, JeTx5, LXSS, SABBAI, Yodo, jesiotrot, zorb_rules, mx6t91, boki82, tomee, broken diff, adylim, my1stmx6, joe91mx6, sik_turk
Lim@ is offline   Reply With Quote
Old 6-1-05, 10:39   #19 (permalink)
  Total: 200 Power: 5
yeah but woo created it cause of the lack of supportr heer in oz for australian ecu's otherwise im sure he would have just used zombie...since he used there work and results anyways in development
Mods:
Old 6-3-05, 19:15   #20 (permalink)
  Total: 178 Power: 4
tx5turbo's Avatar
Are those power outputs realistic?
R32 - RB Goodness
tx5turbo is offline   Reply With Quote
Old 6-5-05, 15:04   #21 (permalink)
  Total: 63 Power: 4
i was wondering the same thing, cos im planning on doing woos as a temporary measure until i can save up for a stand alone
88 VL Turbo Sedan - Shhhhhhhh Tu Tu Tu Tu
http://www.myspace.com/vehslx
TXSTYL is offline   Reply With Quote
Old 6-5-05, 17:47   #22 (permalink)
  Total: 200 Power: 5
I believe they are from what I remmeber talking to barry most of them are based on dyno runs...
Mods:
Old 6-17-05, 23:40   #23 (permalink)
  Total: 14 Power: 4
so if i get one of these chips i could pull 180 kw out of my mx6 just out of a chip....it seems like heaps hey...my mx6 and any mx6 comes out with 100 kw stock and maybe chuck a couple more on that for the pod filter, and the exhaust system...and with this chip i could gain an extra 60+ kw...if some one can prove this to me ill get one straight away....
000mx6 is offline   Reply With Quote
Old 6-17-05, 23:52   #24 (permalink)
MX6
  Total: 20 Power: 5
The ability to read is worth another 10 kW
Originally Posted by zorb_rules
What are the advantages/disadvantages
Advantages
Power is up by 60HP from stock. (most of which comes from safely running more boost).
How much power and torque does this upgrade give me over stock
Depending on which level your car is at to start with.
Stock + 15psi =>130kW and 340Nm
Exhaust, hi-flow +15psi => 180kW and 440Nm
MX6 is offline   Reply With Quote
Old 6-18-05, 0:00   #25 (permalink)
  Total: 200 Power: 5
That it is, that it is
Mods:
Old 4-11-06, 11:15   #26 (permalink)
  Total: 472 Power: 5
can someone list the chipable ecus he can do at the moment ?
1991 Mazda Mx6 - 14.6@96mph, Exhaust, Coilovers, FMIC, Bov..
1961 Humber Super Snipe S3- Restoration Project !
1984 Toyota Corolla AE71 Wagon- Daily Driver !
Originally Posted by SixSick6
Mazda knew what they were doing when they designed this car and the componants that go with it.
GotF2TinGD is offline   Reply With Quote
Old 4-11-06, 11:18   #27 (permalink)
  Total: 465 Power: 5
Everything but the F2H3/5's and one other that I don't remember atm.
Teh Telstar can NEVAH lose!
Old 4-11-06, 20:53   #28 (permalink)
  Total: 479 Power: 4
hmm im really interested in this mod...
one thing id like to know, is will it decrease fuel efficiency when it comes to daily driving and highway cruising?
it sounds like it will from this statement:
Economy
If you lift the boost to 15psi, but rarely drive it at 15psi (2 stage MBC) your fuel consumption will go down.
However if you always drive flat out your fuel consumption will be greater than at 7.8psi, but less than a stock unchipped motor at 15psi.
i would only want to be running about 10-12 pounds of boost, but i would consider an ecu upgrade as well if it increased overall power and efficiency of the engine. (read: less fuel use when i want it and more power when i want it)
anyone got any input on fuel use?
^i like the red font too
91turbo666 is offline   Reply With Quote
Old 4-12-06, 1:01   #29 (permalink)
  Total: 200 Power: 5
As barry expalined it to me and as I understood if you have 2 boost settings then you shoudl eb fine petrol will be fine cause you cna just run in low boost when you like and flick to hi when you wnat the extra speed...basically fuel economy will improve if ya run it that way
Mods:
Old 4-13-06, 9:12   #30 (permalink)
  Total: 178 Power: 4
tx5turbo's Avatar
before ya get too excited check you do have a chippable ECU.
