Old 11-12-07, 19:48   #31 (permalink)
  Total: 149 Power: 5
Yeah, I should be able to pop around and have a look.
Welding bell housings together would be an interesting option, as long as the input shaft was the correct length. The diameter of the input shaft needs to match the bearing in the flywheel, although you will be able to change this to some extent.
1968 VW Baja, KLZE engine, 0-100kph=6.0s in the rain...
I'll whip you all, on the sand
www.offroadvw.net/bajawes
Baja Wes is offline   Reply With Quote
Old 11-14-07, 2:34   #32 (permalink)
  Total: 1121 Power: 5
fredio54's Avatar
its been done for the fe3, in oz funnily enough. ive seen a horrificaly destroyed welded bell on a rotary to toyota box conversion. major carnage everywhere underneath.
Old 11-14-07, 7:00   #33 (permalink)
  Total: 715 Power: 5
cam22t's Avatar
Wes, i will stay in touch.
I am picking up the parts car on Saturday, but it wont get sized up for a while as i am finding it hard to get some spare time to paint the ute and put it thru rego, but it will happen.
At the moment i have a Aftermarket ecu to run it and a complete 93 V6 TX5 5 speed to raid for conversion bits and peices.
I do like the idea of welding/blending the bell and i have already tried to find some scrap for an adapter. I stopped in at S&M, but they had nothing that thick. I am going to next try BOA (? from memory) at Brendale.
Have you got any other sugestions ?
Anyway, more info later.
Thx both, for your input.
89 MX6. 4WS. FE DOHC Turbo. Garrett GT2876r Turbo. Wiesco Forgies. EMS 8860 ECU. 3 Inch Exhaust. Torsen Diff. 2500lb RX7 Clutch. 18 inch Rays Sebring ITC-S wheels. Cusco Camber Plates and Coilovers. Bosch 044 Pump. 750cc Injectors.
13.9 @ 106mph on my slippery 18's. 310hp (227kw) atw's
cam22t is offline   Reply With Quote
Old 11-14-07, 9:56   #34 (permalink)
fredio54's Avatar
if input shaft length is an issue, you can go to a steel plate (easy to find and cheap too) and keep it thin. being a heavy ute, it doesnt matter so much really. just a thought.
Old 11-14-07, 19:40   #35 (permalink)
  Total: 149 Power: 5
I picked up 20mm aluminium plate for my adaptor from a scrap metal place at Geebung, just down the road from tradetools (Robinson Rd?)
