#16 (permalink) |
whiteline makes the whole lot!
its all on my car now lol look at www.totalrpm.com/car/59 for pics of the gear |
#17 (permalink) |
I got mine done at K-Mac they should still have both my fornt and rears there for measurements. (sway bars)
#18 (permalink) |
Just ordered my sways, it's from whiteline like you guys suggested, but it'll take at least 7 days, coz they have to custom make it. Also does anyone know if whiteline makes rear struts? because they said that they don't.
So the place i'm getting it installed don't know where to buy struts for the 2nd gen. Can anyone name some brands or shops to buy them from? The only struts that they found are from Trust and it'll cost $400, no way i'm gonna spend $400 on a piece of metal. hehe Cheers |
96' 2WS
XFORCE 4" Muffler, Carbon fiber lightweight airfilter, Viper 791XV responder alarm, 2x12" Infinity subs.. |
#19 (permalink) |
Fitting a fat rear sway bar is easy and makes a huge difference.. most cars have them but from the factory they are designed for comfort not performance and are usually flimsy..
how it works is like a see-saw or cantilever if you like.. When the car is cornering the bar puts downward force on the opposite side of the car (the side that is lifting up).. Giving better contact with the road and less body roll… first thing first removal... The following illustration is an exploded view of the stabilizer bar and its related components. it is a 2 WS set up but not much is diferent other than the shape of the bar.. 1 Stabilizer Control Link 2 Stabilizer Bar 3 Stabilizer Bracket Bolt 4 Stabilizer Bracket 5 Stabilizer Bracket Nut 6 Stabilizer Bushing 7 Stabilizer Control Link Protector 1. Raise and support the vehicle. 2. Remove the two stabilizer bar-to-stabilizer control link nuts. ![]() 3. Remove the two stabilizer bracket nuts. ![]() 4. Remove the two stabilizer bracket bolts. ![]() 5. Remove the stabilizer bar from the vehicle. Installation NOTE: Apply rubber grease to the inside surface of the stabilizer bar bushings. Align the bushing with the installation mark on the stabilizer bar. To install, reverse the removal procedure. ![]() Tighten the stabilizer bar-to-stabilizer control link nuts to 36-54 N-m (27-40 lb-ft). Tighten the stabilizer bracket nuts to 36-54 N-m (27-40 lb-ft). Tighten the stabilizer bracket bolts to 36-54 N-m (27-40 lb-ft). again this is for a 2WS car .. but the only difference is in the pictures . not the procedure.. it is virtually the same… As the aftermarket bar doesn’t have installation marks this point is irrelevant.. and s for the torque numbers .. dont wory 2 much, just dont leave the bolts loose.. This is my white line bar installed ![]() .. I just opened up the brackets by mildly taping/hitting them with a hammer till they fitted over the large polyurethane bushes supplied by white line.. I do believe you should use the supplied bushes, as the are firmer and will give better results.. Alternatively you can “trim” the poly bushes with a knife or using a bench grinder. A grinder will give the best results and be faster… Good luck… |
People that think they know everything seriously annoy those of us that actually do. |
#20 (permalink) |
I'm searching for a 1gen 4ws rear swaybar upgrade and I guess its mentioned that whiteline makes one?
I am also in search for polyurathane bushings for the rear since the 2ws and 4ws rear bushings are different. Any help would be appreciated. thanks |
05 STI
#23 (permalink) |
as most have said already change ur sway bar first, for a stiffer one, then go for the strut bars, i had both front and rear in my old baby a 2nd gen and she had awsome handling even with stock srings, and stock sway bar, so u can emagine how good it's be if u change the hol lot
Dont
me coz im faster |
#25 (permalink) |
His Royal Freshness
the car handles like gold now
![]() with 17s, front and rear strut bars, plus the whiteline swaybar! and still on stock springs |
Jesus said to those who believed in him "if you obey my teaching, you are really my disciples; you will know the truth and the truth will set you free." JOHN:8:31-32 ![]() |
#29 (permalink) |
Yes, still waiting!!!
1993 Mazda MX6 4WS![]() 2004 Mazda RX8 Luxury![]() "If it was so, it might be; and it were so, it would be; but as it isn't, it ain't. That's logic." - Lewis Carrol |
