Old 8-21-05, 22:46   #31 (permalink)
  Total: 281 Power: 5
Originally Posted by The MichelinMan
there in the main therad!
Which thread?
1993 Mazda MX6 4WS
2004 Mazda RX8 Luxury
"If it was so, it might be; and it were so, it would be; but as it isn't, it ain't. That's logic." - Lewis Carrol
Cromax is offline   Reply With Quote
Old 9-7-05, 5:33   #32 (permalink)
  Total: 95 Power: 4
i didn't want to start a new thread so i thought i'd post in here hopefully someone can help me out... do the front strut bars for an mx6 1st gen fit a tx5? i'm assuming they do but not sure... same question for the mx6 1st gen rear sway bar
14.2@101mph
DQUIK1 is offline   Reply With Quote
Old 9-8-05, 8:32   #33 (permalink)
  Total: 304 Power: 5
the front strut will 99% sure.
rear sway bar, MAY differ depending on 4ws or not. but the 2ws one should be a defi fit
1990 GD mazda mx-6 turbo 4ws, Td05H turbo, custom manifold, 2500lbs rx7 clutch, 18" wheels with 225/35/18 rubber, Short Shifter, super lows, KYB struts, CAI, Exhaust, twin pot Liberty GT calipers, walbro 255lph fuel pump, 18mm rear swaybar
Traded With: Crazyone, Adamx6, Mitchyboy, TX5F2T, JeTx5, LXSS, SABBAI, Yodo, jesiotrot, zorb_rules, mx6t91, boki82, tomee, broken diff, adylim, my1stmx6, joe91mx6, sik_turk
Lim@ is offline   Reply With Quote
Old 9-9-05, 6:47   #34 (permalink)
  Total: 138 Power: 0
front strut should fit, providing there is bonnet clearance, as for sway bars they possibly both 2ws and 4ws not be able to fit.
had to correct u again lim@weed
LX SS is offline   Reply With Quote
Old 9-9-05, 20:55   #35 (permalink)
  Total: 443 Power: 5
LX how did you correct him? cause he said may fit and you said possibly will not? Same thing dude.
Teh Telstar can NEVAH lose!
Old 5-13-06, 20:02   #36 (permalink)
  Total: 304 Power: 5
for guys wondering. a 2g front strut bar can be modified slightly to fit a 1g. the difference is in the hole spacing at the strut top. the mounting will need to be grinded away a bit to make it fit. also you'll need to play around with the other brackets around there, and seeing which nuts need to be there and which ones can hold brackets and strut bar mounting at the same time. this is because of bonnet clearance.
if you just stick the strut bar striaght ontop of all the other mountings with all the other nuts on, you wont be able to close the bonnet.
if any1 is really interested ill take a pic. but its easily doable, takes about 1/2 an hour. is a fairly easy thing to get your head around, just take the strut bar mountings, go to fit it, see where the holes don't line up and grand away with a dremel etc till it fits. and it wont move around if done properly either, its hard to explain why, but even tho the holes are bigger than the strut bolts, they are in such a way they cant move either side, because of the other bolts (urgh, i don't expect anyone to understand that! :P)
but don't be shyd away buying a 2nd gen one if you find one and cant get a 1g (whiteline make a 1g one tho!)
also, thanks to sabbai for this, he was the one that showed me it could fit and had the dremel i needed! (sorry, hafta spread round first)
Old 5-14-06, 3:41   #37 (permalink)
  Total: 200 Power: 5
jase just to correct ya can stick it ontop of other nuts or at least with the tx5 anyways thats how mines is doen
1991 Tx5 Turbo AV 103KW on 12psi
Mods:
Hi Flo'd Turbo, 2.5" exhaust 4" Tip, 15" Pioneer Sub, 2xAmps, CAI, Woo's Mod, Boost Controller (14psi), Autometer Liquid Filled Boost Gauge, Pod Filter, Hi Flow Comet CAT, SUperlow Springs, Rear Strut Brace, WRX Front Bar, Front Strut Brace, FMIC...Soon To come: Zender Side Skirts
zorb_rules is offline   Reply With Quote
Old 5-14-06, 4:29   #38 (permalink)
  Total: 304 Power: 5
you can, but some need to be taken off. or else it sits too high! scotts aswell!
Old 5-14-06, 7:10   #39 (permalink)
  Total: 281 Power: 5
Won't putting it on top of other nuts cause more flex in the assembly? I thought the whole idea of the strut bar is to reduce flex to an absolute minimum.
1993 Mazda MX6 4WS
Old 5-14-06, 17:19   #40 (permalink)
  Total: 200 Power: 5
it will chromie but only slightly and no tenough to reduce the overall effect of the strut bar by any means
Mods:
Old 5-15-06, 3:37   #41 (permalink)
  Total: 375 Power: 4
Turk's Avatar
Does anyone know how the ebay strut bars hold up. Are they strong enough etc. They seem like a much cheaper alternative to what else ive seen. 50ish compared to 200ish.... I mean it is just allimunium right??? as long as the brackets fit nicely
Turk is online now   Reply With Quote
Old 5-15-06, 7:24   #42 (permalink)
  Total: 304 Power: 5
well i got an ebay one. lol its firmer than the whitline one! no doubt! and i couldnt care at all aobut the looks, but it looks good to me! :P
Old 5-18-06, 21:34   #43 (permalink)
  Total: 229 Power: 4
For ebay bars read some of the comments some people say they don't do anything they are so easy to bend
The "PIMP MY PROBE" Project
Status: Engine Bay Dress up
Latest Update: Engine Has Been Powder Coated Silver next is Silver braided hoses in engine bay
NiN^_^NiN is offline   Reply With Quote
Old 5-18-06, 22:09   #44 (permalink)
  Total: 391 Power: 5
what exactly was wrong with the whitleline bar? any pics of it? nost of the bars on ebay are poor qualility and as mentioned will flex. adapting a 2gen bar by making the wholes bigger won't do anything either but provide a little bling
05 STI
92 Galant VR-4
90 Eclipse GSX HKS' Former Promo Car
89 MX6 GT 4WS SOLD 89 PGT R.I.P
93 PGT5
/93 PGT5-SOLD/89 PGT-R.I.P. /96 PGT5 R.I.P.
KiNg MaRtY is offline   Reply With Quote
Old 11-18-07, 4:09   #45 (permalink)
  Total: 35 Power: 2
I'm thinkin of getting whiteline rear sway bar for my 1st gen Mx6 too. Its also 4WS. I heard whiteline makes very good sway bars. If u wanna feel real good response when u turn, Just install coilovers and drop it. lol
Red 1st gen Kia Shuma, lightly modified.
Bronze 1st gen Mazda MX6 Turbo, modified
http://www.modifiedstreetcars.com/ca...Turbo&p_id=483
marky84 is offline   Reply With Quote
