Go Back   Mazda MX6 Forums: MX6 Forum > Regional Forums > Canada > Eastern Canada
Old 7-30-09, 22:23   #1 (permalink)
  Total: 15 Power: 2
engine stalling..
hey guys.. a while ago as i would pull up to a red light and slow down the car would just stall this happened about 2 or 3 times.. i thought it was just bad gas or sometime.. and didn't give it much thought... but recently the past 3 days as I drive the car at around 80km/h the car stalls... and then if i start it.. it just starts back up.. and once it wouldn't start right away but after 30 secs it started up just again... and then it drives fine.. so on a 50min trip it might stall after about 15-20 mins and be fine for the rest of the trip..
so far i've done a fuel pressure test with Kevin's help.. didn't see any problems there and yesterday i changed the distributor cap and rotor.. still stalling...
any of you guys had an issue like this before ??? or know anyway to pinpoint the problem ?
z-man is offline   Reply With Quote
Old 7-31-09, 0:03   #2 (permalink)
  Total: 584 Power: 5
I've never had an issue like that, really weird...try re-posting this in the 2G General Section, more likely to get more info/responses there.
1997 Mazda MX-6 LS KLZE
In Jeonju, S.Korea for now...damn I miss my MX-6
Old 7-31-09, 0:43   #3 (permalink)
  Total: 76 Power: 3
make sure your oil cap is on lol
no longer an mx6 owner...
redbond1 is offline   Reply With Quote
Old 7-31-09, 9:11   #4 (permalink)
  Total: 408 Power: 5
PaulG's Avatar
Sounds like the disty is failing. You should swap one of Kevin's old ones in if it's the same year and see if the issue persists.
1997 MX-6 LS
Old 7-31-09, 11:33   #5 (permalink)
  Total: 15 Power: 2
Ya Kevin suggested the same thing. He's looking for it and when he find's it i'll give that a try...
Old 8-4-09, 9:58   #6 (permalink)
  Total: 219 Power: 5
Curses! I didn't phone you back, did I? My bad.
Okay, I found two, and since one looks very odd, I'm going to guess that to be the KLZE one, so the other should be my old working one. I'll be around Wednesday evening after 4:00 if you wanted to stop by, then we could swap the disty real quick, and I can whip out the timing light and we can make sure that its still set right.
If that doesn't work, give me a call and we'll figure out a time.
1993 Blue Shogun MX6 - KLZE, CAI, STS, UDP, HEI Mod, External Coil, SSAC Headers, MagnaFlow Cat, 2.5" Catback, DynoMax SuperTurbo Muffler, Resonated Tips, Tokico Blues, 16mm 626 Sway Bar, 17" Chromes, Fuzzy D20's (adds 2xD20 HP!)
Richard Biggs is offline   Reply With Quote
Old 8-5-09, 23:32   #7 (permalink)
  Total: 15 Power: 2
so on the way home sometime after leaving your place the engine light started coming on for a sec or two and turned back off.. it did that 3 or 4 times but didn't stall..
Old 8-6-09, 7:21   #8 (permalink)
  Total: 219 Power: 5
Have you checked the codes again? Here's hoping a code stuck this time, hopefully you can get it checked before the computer resets itself.
PS:> That's exactly why I keep that wire under the hood there for jumping the diagnostic box; when I see a code come up like that, I just pull off to a parking lot immediately and check my codes.
Old 8-8-09, 22:04   #9 (permalink)
  Total: 15 Power: 2
finally checked the codes today and got 17 oxygen sensor...
Old 8-9-09, 17:38   #10 (permalink)
  Total: 219 Power: 5
Well, I guess the good news is that now we know what your CEL code was for. But I'm supposing the bad news is likely that replacing an O2 sensor didnt' stop the stalling. :P Seems pretty unlikely to be the root cause. Keep us posted!
Old 8-21-09, 13:37   #11 (permalink)
  Total: 15 Power: 2
Ok so.. tried the different ecu in the car and same thing's happening... then checked to see if there was a spark after stalling but it would just start back up... after numerous tries we finally got under the hood quickly and there was no spark at all..
