Go Back   Mazda MX6 Forums: MX6 Forum > Open Forums > General Automotive > Engine Management
Old 11-5-09, 10:04   #1 (permalink)
  Total: 150 Power: 4
1990-1992 MX6 Turbo DIYPNP application guide is up!
We've got a base map and jumper guide to make building your own DIYPNP and putting it in your F2T MX6 a snap. Check it out here:
DIYPNP MegaSquirt installation for the Mazda MX6
Big thanks to Garfield for letting us test this out on his car. Next DIYPNP test car is a '93 Probe with a KLDE!
Matt Cramer
DIYAutoTune.com - Megasquirt, fuel injectors, wideband O2 sensors, and more
Matt Cramer is offline   Reply With Quote
Old 11-5-09, 13:09   #2 (permalink)
  Total: 1075 Power: 5
zlyricist's Avatar
very nice indeed. great work you guys are doing! maybe i missed it, but what are the wheel decoder settings using both stock vr sensors?
1991 MX6 GT - my slut
95 LS SOLD - 96 M edition SOLD - 93 KLZE new daily
Old 11-5-09, 14:15   #3 (permalink)
  Total: 22 Power: 2
do you guys already have one for the 88-89?
89 Ford Probe GT28r
Never Scared to Be Different.
90probef2t is offline   Reply With Quote
Old 11-5-09, 14:53   #4 (permalink)
zlyricist's Avatar
i dont think much is different on the 88-89, except the grounds on the disty, and wiring pinout. with a wiring diagram. you shouldnt have any issues getting it to work the same
Old 11-5-09, 15:47   #5 (permalink)
  Total: 150 Power: 4
It's in the big spreadsheet, but here are the settings specifically:
Spark mode: Toothed Wheel
Trigger Angle: 10
Ignition input capture: Falling Edge
Spark Output Going High (Inverted) Warning: Other output circuits besides the DIYPNP may be different!
Number of Coils Single Coil
Dwell type Standard Dwell
Maximum Dwell 5.1
Trigger wheel arrangement Dual Wheel
Trigger wheel teeth 24
Missing teeth 0
Tooth #1 angle 5
Wheel speed Cam
Second trigger active on Falling Edge
and every rotation of Cam
Not yet. Give us about a week for the cases to show up and you'll be able to buy a DIYPNP that fits this car. The base map should be the same, but the jumpers will be different.
Matt Cramer
Old 11-5-09, 15:51   #6 (permalink)
  Total: 22 Power: 2
awesome. thought i would ask cuz i thought that i did here that the 1genA and 1genB were a tad different.
89 Ford Probe GT28r
