cylinder crack - anybody?
![]() And here I was just thinking I had a head gasket problem. Actually, I still think I do/did, but this happened during that time. This is a 2000 Kia block that was overbored 3mm. It's got about 400 miles on it, of which maybe 5-10 were under boost, and of those most were no more than 6psi. It saw 8 psi maybe five times. I've got a full gauge set (egt, oil temp, oil press, coolant temp, knock sensor, wbO2...) and never saw anything suspicious on the gauges. There was high crankcase pressure, so I assumed that the head gasket (copper w/o embossing or o-ring) was leaking compression into the crankcase via the oil drainbacks. I did a compression check, which confirmed the head gasket problem- after 400 miles the compression numbers were the same as pre-build numbers (1=140, 2=120, 3=120, 4=180). I'd orginally assumed those numbers were results of a non-broken-in engine (rings not seated). I pulled the head Sunday morning to find the crack. Other cyldiners looked fine, and this was the only sign of failure. Piston tops are clean, cylinder walls look good. I'm willing to chalk this one up to a weak casting by Kia- unless somebody can convince me otherwise. Usually you see something else break before a cylinder wall. Fortunately I still have my original Mazda FE3 on the engine stand, and have already started moving parts over. I just hate to lose that 339cc. I guess it will happen, just later. - rob |
#2 (permalink) |
maybe you bored it out to much for it to handle the stress under boost. Not sure what the bore limit is though.
Stock: 15.446 @ 88.78 F2T Best: 12.71 @ 104 FE3T: 11.941 @ 99.03 (missed 4th) 470 WHP Turbonetics 50 trim @ 30psi videos:http://videos.streetfire.net/uploaded/Shwine617.htm |
#9 (permalink) |
.139 - no trouble- it's all the same amount of work and cost. Rather 1mm over, why not go to 3mm for the "free" displacment. I guess the real reason for the 3mm over, was the fact that forged JE 89mm (3mm over) pistons were picked up on eBay for cheap (something like $200).
#10 (permalink) |
are you using pistons made for an fe3 or are they for a dsm or something?
#12 (permalink) |
i'm sorry to hear about your crack. it would be somewhat ironic to all of the "randys page" following mx6 public if it was a bad idea to bore that much.
looking at the other side of the bores, its apparent that there is only about 5mm of meat there, and also that it is porous and rough cast on the surface(and therefore of variable thickness). i still would've thought you'd get 1.5 out of each side without issue though. i guess you and randy just got unlucky on that particular block. and him on the one before it too. better luck with the next one :-) what did/does randy do for a living anyway? it was alluded to but never mentioned. i've always been curious. fred. |
#13 (permalink) |
That's the risk with doing something first. I knew that. It's only painful when the parts you haven't modified or manipulated fail for no apparent reason.
Oh- and this is Randy's block. I was going to stick an untouched Mazda FE3 in and when this came up for sale- I figured why not. Same amount of work- just more motor. And most of the Mx5 oriented stuff was sorted out. The decision for the overbore amount was ok'd by his engine builder based on cylinder wall thickness. That said, I would have probably gone with the (my) engine builder's recommendation also. Once it's disassembled, I'll check out the casting on the coolant side. Hopefully I'll find a bad spot- otherwise I'll be using smaller pistons for a 2.2. I'll also get the builder that put together my last race motor to look at it- he's good. Either way I'll update this thread with results for others. Maybe it'll reveal some QC issues with Kia castings? I know the previous Kia block he was using had a crack in the casting on a coolant path. I think he's something like a internet commerce consultant for corporations. He's just a BIG mazda geek as a hobby. - rob |
