Crankcase ventilation discussion and sort of survey
the options are :
(best) vacuum generated by dry sump pumps or just crankcase evacutator pump (good) pcv valve to allow engine to draw air in from crank case at idle and open pipe to intake in front of turbo as per stock setup. (ok) to vents via seperators and filters (sh|te) just open to the world (going to blow) closed sealed and about to spit out some seals have i missed any, and what do you have on yours? just thinking about what to do after someone from here prompted me about it. fred. |
#6 (permalink) |
i bought a greddy catch can and was kind of confused on how to hook it uo, you have any pics of a catch can set up?
Stock: 15.446 @ 88.78 F2T Best: 12.71 @ 104 FE3T: 11.941 @ 99.03 (missed 4th) Best MPH: 12.24 @ 117.03 videos:http://videos.streetfire.net/uploaded/Shwine617.htm |
#8 (permalink) |
Experiment 626
I'm running a PCV valve with a breather filter on the side of the cam cover. One of these days when i re-do my piping I'd like to have it connected to the turbo inlet but for now it works ok.
I personally like Volvo's ventilation setup. It's got a factory catch can, that just drains the oil back into the sump for re-use. |
Anarchyx
'98 VW Jetta K2- Daily driver. '94 Miata C-package- Tein S-tech, Tokico Illumina, FCM bump stops & 15" OZ Superleggera, MSPNP |
#9 (permalink) |
The mazdaspeed cars have catch cans with drain backs.
I considered it, but after looking at the nasty stuff in the can, I figured I'd rather keep it out of the engine. |
#12 (permalink) |
I'm running both lines to a catch can. I plan to keep an eye on the can to see what develops. I was pondering the need for a PCV valve myself but decided to just stick with the plan for the moment.
This is an old pic but the set-up remains the same: http://www.car-hole.com/photohole/Pr...)/DSC01897.JPG |
Project Mazda TT (Turbo Truck)
#13 (permalink) |
fair enough. did you get your oilly froth on the engine that died? or the new one? or both?
odd ball : those lines look really small? i imagine that with the length of them the oil particles would have a hard time making it to the end (probably a good thing unless you formed a hydraulic lock because of it) fred. |
#14 (permalink) |
Mr. Gasket Crankcase Evacuation System - JEGS
I've been running a hose from the valve cover to a catch can which then goes to one of these welded in the exhaust. It works by using exhaust gases to draw the gasses out. evo |
