#46 (permalink) |
any chance of grabbing an f2 piston and photographing that with the f2t one?
i guess this means fe3 pistons make really good f2 high comp pistons too. that is if you were crazy enough to do that sort of thing :-) i know one person is. here are your pics cropped, resized and rehosted : ![]() ![]() ![]() fred. |
#47 (permalink) | |
did something useful today though f2t piston is 28 cc. my fe3 head is 47 cc ( might be shaved a little before i got it ) head gasket is 1mm so with f2t pistons in a stock fe3 ( means cranck and rods) gives a 7.2 cr acording to my calculations ( feel free to check) thats to low for me but might be a good idea if someones interested in pushing some bigboost in a fe3. have to recalculate it with the 2.2 crank. i did calculate it but asumed that the cupper fe3 head gaskets were 1.6 mm thick but just heard they were 1.1. so... to be continued |
#50 (permalink) |
if you use the stock fe3 cranck those would be nice indeed. but according to my latest calculations with a 2.2 crank and fe3 rods and shaved f2t pistons i get a 8,6 cr. so with a little porting of the head this would also be a good 400 hp cheapass mod! including 200cc extra displacement!
#55 (permalink) |
the stress on the ring lands is directly related to torque as this is directly related to the presuere in the combustion chamber.
a f2t pushes 400 nm easely ( because of the max hp at verry low rpms deu to the long stroke) so with half the ringlands and have the torqe you can easely push 200 hp at higher rpms with half the amount of stress in the combustion chamber. so absolutely no problem N/A and under boost??? who knows?? im gonna test it for you guys! |
#56 (permalink) | ||
#58 (permalink) |
hey fred, what is the compression on the fe3 piston ? cause im looking for a cheaper high compression piston for my lx, and if the fe3 piston is the same size, diameter, compression as the kia
