Old 11-19-07, 3:52   #76 (permalink)
  Total: 1203 Power: 5
fredio54's Avatar
Originally Posted by chief tool View Post
Yes I did mean SOHC....I usually refer to the DOHC as the FE3
good man, lots dont and i find it a bit annoying :-)
Old 11-19-07, 4:08   #77 (permalink)
  Total: 2620 Power: 5
http://www.mx6.com/forums/1g-mx6-oth...n-chamber.html (P&P on my combustion chamber...)
Julios pistons were .040 over 87mm for the GT. Not forged so the compression ratio of the pistons themselves wasn't known when he ordered them.
Old 11-19-07, 5:13   #78 (permalink)
  Total: 361 Power: 3
Interesting....I never knew about the perspex trick, i usually use steel ruler on edge across the face, and when the fluid touches the edge its on the money.
I like the pipette as it measures the amount of fluid going in to the space....it's way more accurate than you need for compression, maybe not for NASCAR rules.
I'll have too keep those figures written down. head 49cc, turbo piston dish 25cc
when I back check my figures against those....if there was no head gasket thickness taken into account, the figures from the thread sick added would indicate a c/r of 8.38, but we know its 7.8 according to the factory.
according to my figure of 17.8cc using 49cc for head volume I get a c/r of 9.17, which is 0.79 points higher...
the factory c/r of 8.6 is 0.8 points higher than the turbo, so I'd say my measurements are pretty accurate.
Old 11-19-07, 5:17   #79 (permalink)
No, read it again, 87mm aftermarket piston.
Old 11-19-07, 12:51   #80 (permalink)
  Total: 770 Power: 0
Is there any chance you'd be willing to CC those pistons? A medicine syrine and water with food coloring is all you'd need. (just clean them up, pour the water in the dish and pull it back out with a syringe, then tell us the numbers)
Has anyone done this yet? I didnt see anywhere in here where they did...
If so, I can do it tomorrow with my old set of F2t pistons.
Old 11-19-07, 12:56   #81 (permalink)
fredio54's Avatar
go for it anyway, a cross ref of one dodgy internet dude against another is always a good thing to have
Old 11-19-07, 13:34   #82 (permalink)
All aboard the B& V&
  Total: 1693 Power: 5
Zach's Avatar
This is some inherently interesting developments
Old 11-19-07, 21:09   #83 (permalink)
  Total: 361 Power: 3
tried to read it quickly, must have missed that bit....but if they were meant to be OEM replacements, the manufacturer would have tried to keep the specs as close to factory as possible.
Old 11-19-07, 21:11   #84 (permalink)
  Total: 361 Power: 3
yes.......there is nothing like measuring it yourself to confirm when the time comes. all the figures I would take as a guide only.
Old 11-20-07, 5:39   #85 (permalink)
fredio54's Avatar
I wasnt implying that you were dodgy :-) just that the more measurements that confirm the same figure are available, the better :-)
Old 12-9-07, 7:48   #86 (permalink)
  Total: 156 Power: 3
i have some pistons laying around here.
have my f2t pistons, my fe3 pistons my sr20det pistons and have casejunkies f2 pistons.
anyone need some pics or specs just tell me and i'll post them
bakmans is offline   Reply With Quote
Old 12-9-07, 19:43   #87 (permalink)
I've been waiting to see CC values for the F2 vs F2T pistons since forever so yes..please CC them. Karma will be waiting.
Old 12-9-07, 21:27   #88 (permalink)
  Total: 361 Power: 3
I did the F2 ones, but I dont have a set of F2T ones except for the ones in the engine thats in the car ATM..
over the holiday period, i'll speak to my mate who runs a yard and see if he has any junkers that I can have for free to measure.
Old 12-9-07, 21:29   #89 (permalink)
So how many CC were they? ( I missed that) and were they the stock 86mm bore?
Old 12-10-07, 1:33   #90 (permalink)
  Total: 361 Power: 3
F2 = 17.8cc
And yes they were out of a standard bore...
