#31 (permalink) | ||||
most of it is listed publicly on the net.
i have ms2 with v3 board and would recommend the same to anyone. mine runs ms2e2alpha software, but ms2e release is pretty close, and the late betas are pretty fricking good indeed. costs: ms2/v3 see diyautotune for price on diy/built versions innovate lc1 see diyautotune for price on this hybrid fe3/miata cas built by me from parts of existing fe3 and miata cas given to me by a dodgy guy. sierra granada 36-1 and vr sensor given to me buy inlaw from uk. coils, stock fe3 lying around ditto ignitors leads nz$5 each custom machining to fit the trigger wheel to the crank, free, did it myself on a uni lathe. etc. ie, the main costs are obvious or application specific. Quote:
although i'd never try it without a wbo2 sensor, you can do it. simply, you tune it rich such that it misses etc, then you lean back a bit, then you advance in the usual fashion. in cruise, you lean it out as much as you can, and adjust idle to be smoothest with best vacuum. in short, you can do it, but you need good judgement. i like precision, so i'll always use a wideband. Quote:
#32 (permalink) |
i dont get as consistant info as you did so the thread would be slopy and slow, but currently my engine has been at my machineist for a month and a half. This i because i live on the second floor of a small appartment or else i would have completed it allready, but he does great work. The EGT thing is the most reliable tool for tunning your timing advance or retard. That is what we use on ProMods and they run like 4.21 et's and at 164 mph in the 8'th mile.
#34 (permalink) |
ya i have already set up an account. Im just wating to pay for the items in my cart. what i was shooting for are the things you need that people dont think about and the total cost of your setup.
#35 (permalink) |
theres a reason that those things are hard to quantify :-)
i could fwd you copies of my bank statements if you like. then you could quickly remove gas and food, and all that would be left would be trusty ute bits :-) there is also a difference between a minimal installation and a hardcore one. ie, one fuel pump, no surge tank, stock wiring loom merged onto a db37, etc. compared to two fuel pumps, surge tank, hard out filter, custom high temp wiring loom, etc etc. i wouldnt have a clue what i spent on all the small things. i can hardly remember what i spent on the big things. fred. |
#37 (permalink) |
I was just trying to set up a budget for the conversion and trying not to forget anything. Now if only i was done with college so i would have time to catch up all of my projects, like the f8d1 to fe3n-t. I cant wait to see the diffrence in tourqe and hp as apposed to the f2 and f2t i drive daily. The only thing i still need to reed is the peramiters and signal outputs for the diffrent sensors along with the spark options avalible, I love MSD. What othe options are out there for MS and spark besides EDIS and now the option of hooking up the factory distributor. How well does this work anyway? I still have the factory dissy from my F8 and would rather hook it up instead of a trigger wheel and VR sensor.
#38 (permalink) |
you can use the optical sensor to trigger the ecu regardless of whether you use the rest of the dizzy to do anything. then you can run your choice of wasted spark or cop setups with any number of (somewhat pointless under 30psi) boxs for cdi etc...
two factory wasted coils or four factory fe3 coils and ignitors and you are away! fred. |
#39 (permalink) |
i never linked pics of my board to this thread, so here they are :
front of board http://i50.photobucket.com/albums/f3...4/100_4034.jpg back of board http://i50.photobucket.com/albums/f3...4/100_4033.jpg db37 end of case http://i50.photobucket.com/albums/f3...4/100_4017.jpg db9 end of case with led mods and switch for bootloader mod http://i50.photobucket.com/albums/f3...4/100_4016.jpg and the page of my mega thread with the ms info in it. http://www.mx6.com/forums/fe-dohc/18...st-here-6.html (Freds FE3 into the ute swap DONT POST HERE.) my worthless msq for an early ms2extra v2 alpha is on msextra.com somewhere under my old username rb26dett. thread might be called standard toothed wheel dual trigger or something similar. fred. |
#40 (permalink) |
here is the post with my worthless old msq in it :
MSx/Extra EFI :: View topic - Alpha test: regular missing toothed wheel you have to be logged in to download it. fred. |
#45 (permalink) |
my home made and modified stim with ribbon connecting it to my v3/ms2 with edis and paranoid reliability mods before code became available for COP and i modded it again.
![]() that stim is known as v1 or something now. there is a new different design with more chips and more complex, and also a cool PIC based one that can simulate trigger wheels of many types for COP/wasted setups. those are a bit more expensive though, but with mine it wasnt possible to test it fully before installing. which worked out ok, but isnt ideal if its your daily or something. fred. |
