Old 12-8-07, 14:21   #46 (permalink)
MX6.com Supporter - Click Here for Information 4ws newbie
  Total: 88 Power: 2
Wibla's Avatar
Stupid question: whats the syringe for?
'88 Mazda 626 2.0i-16 4ws
Wibla is offline   Reply With Quote
Old 12-8-07, 15:15   #47 (permalink)
  Total: 1030 Power: 5
Dutch's Avatar
to change airpressure on the MAP sensor.
You, sir, are full of awsome.
Old 12-8-07, 15:50   #48 (permalink)
  Total: 1192 Power: 5
fredio54's Avatar
exactly :-)
Old 12-8-07, 19:28   #49 (permalink)
  Total: 88 Power: 2
Wibla's Avatar
For testing then, I assume?
Old 12-8-07, 20:07   #50 (permalink)
fredio54's Avatar
yeah, the point of posting the pic was to show the "stim" as i built it, different to any other out there...
thats the only reason i posted it.
Old 12-10-07, 5:36   #51 (permalink)
  Total: 156 Power: 3
i finaly got my ms running. tested it on a car that was already megasquitred. just copied the maps and plugged it on an it ran!!
now we have to fix dutches ms and build some fe3t's
bakmans is offline   Reply With Quote
Old 12-11-07, 18:56   #53 (permalink)
  Total: 252 Power: 4
lundgren420's Avatar
just a few questions, i have been spending some spare time reading the ms page and the site says tha ms1 is for fuel and ms2 is for spark and fuel ? but i read here that some of you run spark with ms1 how does that work? I am ready to order but dont want to order one that only does fuel controle. Please help.
1989 Probe GT M/T -my new toy
Old 12-11-07, 19:33   #54 (permalink)
fredio54's Avatar
simple, the admin on msefi is a total [fizzle]ing wanker called lance. it is banned to mention msextra on msefi because of the chip on his shoulder about the msextra devs.
spend your time reading MSx/Extra EFI :: Index and its manuals and posting there, and you will be a lot happier.
MS2/Extra Manual Index is the manual for ms2e
fred.
Old 12-12-07, 15:46   #55 (permalink)
  Total: 935 Power: 5
zlyricist's Avatar
ive got everything assembled on the board with the exception of only a few components. im gonna run a MS1 v3.0 with high resolution code.....
for those running stock igniter/coil/disty, did you opt to use the high current ignition output (vb921) straight from the board, or go with your stock ignitor?
would there be any benefit in running off the MS as opposed to the stock?
I'm Zlyricist, and I approve this message
91 GT - 95 LS
06 maxima - the daily
Old 12-12-07, 16:27   #56 (permalink)
fredio54's Avatar
no, quite the opposite, the vb921 units are fragile.
high res is only for high impedance. just so that you know...
i used four stock ignitors to power four stock coils.
the power you want almost demands wasted spark though. the signal is good enough for cop like amd did too. without cdi (which you should avoid if poss) you will probably struggle to use one coil to 7500rpm and high boost that you intend to run.
fred.
Old 12-12-07, 16:37   #57 (permalink)
fredio54's Avatar
i thought for fairness of info, you might like to hear about some other options too:
VEMS, more $$$$$$$ more features, more io, faster cpu, little support, unfriendly creature. code finished and not in development. devs hated by original ms people.
Versatile Engine Management Systems - www.vems.hu
this lot are manufacturing their own too, but the same code runs on them. the original ms croud hate these guys too, and they are also more $$$ but nothing more performance wise at all.
Welcome To M-Tech Automotive Limited | Suppliers of MegaSquirt and Throttle Body Systems
this was officially allowed by lance to occur (not only an arsehole, but also stupid) :
MiniMs Website
its a minaturised version that runs with the early code and has a wideband on board.
i recommend ms2/v3.0 because of the level of support and active ready to help devs among other reasons. this despite being banned by them from all sites :-)
just thought i'd spread some info for you all.
fred.
Old 12-12-07, 19:04   #58 (permalink)
  Total: 935 Power: 5
zlyricist's Avatar
well than coil packs it is.....im gonna need to redo some of this crap
91 GT - 95 LS
Old 12-12-07, 22:08   #59 (permalink)
  Total: 252 Power: 4
ok Fred i got a chance to make some PDF's today at work and tonight printed an MS book 564 pages, these were the articles
MM40_Wire&Sensor
MegaSquirt - Electronic Fuel Injection Computer by Bowling & Grippo * * ©2005
MSnS Extra Ignition Hardware Manual
Troubleshooting Communications I
Common MegaSquirt Modifications
MM50_V3assemble
MSnS-Extra Hardware Manual
DIYAutoTune.com FAQ / Frequently Asked Questions on the MegaSquirt Engine Management System and Innovate Motorsports Wideband o2 tuning products
MS1 Extra Basic Reference Manual
MSnS-Extra Software Manual
Will the MegaSquirt work with my Ignition System?
MM40_V22Assembly
MS1 Extra Tuning Manual
should make for some good reading this weekend and hopefully answer most of my questions. This thing fis perfectly in a 3"3 ring binder. Thanks
Old 12-13-07, 4:20   #60 (permalink)
fredio54's Avatar
Just make sure you check important stuff with the site again. Errors dont get fixed on your hard copy ;-)
lyriciisisist, i'm not saying you cant do it with one coil, just that you may have misfires under heavy load/high revs. you can always redo it as wasted spark then if dizzy makes getting up and running easier....
